Logical Volume Redefinitions using Generic Messenger and Macro Looping
Hi!
I have defined a generic messenger to change the thickness of my x-ray target in my simulation. In a macro, I have defined it to loop over a certain range. However, upon each run after the first, I get the below error:
*** G4Exception : GeomMgt1001
      issued by : G4LogicalVolumeStore::GetVolume()
There exists more than ONE logical volume in store named: TargetLogic!
Returning the first found.
I do have /run/reinitializeGeometry in the macro, but does something else have to happen when redefining the dimensions of a volume in this way? Thank you!
would you post the code (messenger and what is run by the messenger to change the thickness of the target)? otherwise I believe it would be just wild guessing what went wrong :wink:
of course! Please find what I believe is the relevant code below, let me know if you need any other parts of it:
detectorConstruction::detectorConstruction() //constructor
    G4RunManager* runManager = G4RunManager::GetRunManager();
    Messenger = new G4GenericMessenger(this, "/detector/", "thickness");
    Messenger->DeclareProperty("thickness", Thickness, "Target thickness");
    runManager->GeometryHasBeenModified();
    Thickness = 0.5;
    DefineMaterials();
As you can see, the command to change the thickness is /detector/thickness X where X is the numeric value defined in the loop macro
as I understand, the messenger command alters the value that is stored in Thickness (which is overwritten in the following line with a default of 0.5 anyways, but that is probably not relevant at the moment). This should then influence the thickness within
G4VPhysicalVolume* detectorConstruction::Construct()
method?
How/where do you call the reconstruction of the detector?
Probably the part of detectorconstruction where the Thickness is used in Construct() is also interesting…
Thank you for your help. In the Construct() function, the thickness is simply called as below as I have it listed as a private variable in my header file:
 TargetSolid = new G4Box("TargetSolid", 0.5*m, 0.5*m, Thickness * um);
and constructed as usual (i.e. with the logical/physical volume definitions).
I am unsure about what you’re referring to in terms of ‘reconstruction’ - after I change the thickness in the loop, I run the /run/reinitalizeGeometry macro command which I am under the impression does this reconstruction, but perhaps I am mistaken here?
Thank you for pointing out the Thickness overwrite - that’s an oversight that I’ll fix now!
That was what I meant. Looks fine to me, as it is exactly what is also done in
Not sure about this, but maybe defining the destructor (and deleting the world/experimental hall) could be the solution:
Hmm I seem to be still getting the same error message even with the implementation of the destructor and deleting the world volume in it - not too sure what is going on!
