-- Looking for IceConnectionNumber in ICE - not found
Please fill out the following information to help in answering your question, and also see tips for posting code snippets
_Geant4 Version:_geant4-v11.1.0
_Operating System:_macOS Monterey
_Compiler/Version:_Apple clang version 14.0.0 (clang-1400.0.29.202)
Homebrew clang version 16.0.0;
javac 11.0.2;
Python 3.7.1;
node v19.8.1;
I searched for the reason why" – Looking for IceConnectionNumber in ICE - not found"
But seems, nobody gets this, so I come here to ask help. thank you.
– The C compiler identification is AppleClang 14.0.0.14000029
– The CXX compiler identification is AppleClang 14.0.0.14000029
– Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc - skipped
^C
(base) wangyingdeMacBook-Pro-6585:build wangying$ cmake …
– Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ - skipped
– Found EXPAT: /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX13.1.sdk/usr/lib/libexpat.tbd (found suitable version “2.4.8”, minimum required is “2.4.8”)
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
– Found Threads: TRUE
– Found X11: /usr/local/include
– Looking for XOpenDisplay in /usr/local/lib/libX11.dylib;/usr/local/lib/libXext.dylib
– Looking for XOpenDisplay in /usr/local/lib/libX11.dylib;/usr/local/lib/libXext.dylib - found
– Looking for gethostbyname
– Looking for gethostbyname - found
– Looking for connect
– Looking for connect - found
– Looking for remove
– Looking for remove - found
– Looking for shmat
– Looking for shmat - found
– Found OpenGL: /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX13.1.sdk/System/Library/Frameworks/OpenGL.framework
– Found Geant4: /Users/wangying/geant4/geant4-v11.1.0-install/lib/cmake/Geant4/Geant4Config.cmake (found version “11.1.0”)
– Configuring done (4.8s)
– Generating done (0.0s)
– Build files have been written to: /Users/wangying/geant4/geant4-v11.1.0/examples/basic/B1/build
I don’t think this is an error - CMake is just checking for a feature and, not finding it, will adapt the build as required. Have you tried running the build after this to see what happens?
I tried to run example B1. It was working, with no errors. So I guess it is fine. Just see others all found it.
Thank you for your explanation.
