*** G4Exception : GeomField1001
issued by : G4MagInt_Driver::OneGoodStep()
Stepsize underflow in Stepper !
Step’s start x=27365.9 and end x= 27365.9 are equal !!
Due to step-size= 1.13848e-12. Note that input step was 0.013671
At this x there is no detector and there should not be any field as it is out of the world volume, which is 6m. A user defined magnetic field is used. The field is applied via
G4Mag_SpinEqRhs *equation = new G4Mag_SpinEqRhs(MagneticField::GetInstance());
G4MagIntegratorStepper stepper = new G4ClassicalRK4(equation, 12); // 12: mag field
G4MagInt_Driver driver = new G4MagInt_Driver
(1.0e-3mm, stepper, stepper->GetNumberOfVariables());
G4ChordFinder finder = new G4ChordFinder(driver);
fFieldManager = new G4FieldManager(MagneticField::GetInstance());
fFieldManager->SetDeltaOneStep(1e-10); // improved tracking precision
fFieldManager->SetMinimumEpsilonStep(1e-10);
fFieldManager->SetMaximumEpsilonStep(1e-10);
fFieldManager->SetDetectorField(MagneticField::GetInstance());
fFieldManager->SetChordFinder(finder);
Some observations: the “x” value mentioned is badly labelled. It refers to the distance along the trajectory from the start of the current physical step.
I observe that the accuracy that you are requesting is very high compared with our typical accuracies. In particular the basic 4th order G4ClassicalRK4 integration method which you have chosen will not be efficient for accuracies above 1.0e-4 or so.
Higher order RK methods are found to be more efficient for higher accuracies - see for example the textbook E. Hairer S. P. Norsett G. Wanner “Solving Ordinary Differential Equations I”, section II.6 “Explicit RK-methods of higher order”.
So I would suggest to try higher order integration methods if you need high accuracy, starting with the now default G4DormandPrince745 5th order method, and experimenting with the higher order methods including G4DormandPrinceRK56 and G4DormandPrinceRK78.
I suggest to also add the following line in the printout code for the G4Exception:
