I am currently setting up Geant4 for BDSIM on my Ubuntu system (Windows subsystem). For this the version Geant4.10.4.p03 is suggested and the cmake properties are set as in
The configuring and generating with those properties works just fine, just a few warnings:
CMake Warning at cmake/Modules/G4DeveloperAPI_OLD.cmake:297 (add_library):
Cannot generate a safe runtime search path for target G4interfaces because
files in some directories may conflict with libraries in implicit
directories:
runtime library [libQt5PrintSupport.so.5] in /home/fstummer/anaconda3/lib
may be hidden by files in:
/usr/lib/x86_64-linux-gnu
runtime library [libSM.so.6] in /home/fstummer/anaconda3/lib may be hidden
by files in:
runtime library [libICE.so.6] in /home/fstummer/anaconda3/lib may be hidden
by files in:
runtime library [libX11.so.6] in /home/fstummer/anaconda3/lib may be hidden
by files in:
runtime library [libXext.so.6] in /home/fstummer/anaconda3/lib may be hidden
by files in:
runtime library [libXt.so.6] in /home/fstummer/anaconda3/lib may be hidden
by files in:
runtime library [libXmu.so] in /home/fstummer/anaconda3/lib may be hidden by
files in:
runtime library [libQt5Widgets.so.5] in /home/fstummer/anaconda3/lib may be
hidden by files in:
runtime library [libQt5Gui.so.5] in /home/fstummer/anaconda3/lib may be
hidden by files in:
runtime library [libQt5Core.so.5] in /home/fstummer/anaconda3/lib may be
hidden by files in:
Some of these libraries may not be found correctly.
cmake/Modules/G4DeveloperAPI_OLD.cmake:499 (geant4_library_target)
source/interfaces/CMakeLists.txt:21 (GEANT4_GLOBAL_LIBRARY_TARGET)
Cannot generate a safe runtime search path for target G4OpenGL because
directories:
by files in:
by files in:
by files in:
by files in:
by files in:
files in:
runtime library [libQt5OpenGL.so.5] in /home/fstummer/anaconda3/lib may be
hidden by files in:
hidden by files in:
hidden by files in:
runtime library [libfreetype.so.6] in /home/fstummer/anaconda3/lib may be
hidden by files in:
runtime library [libexpat.so.1] in /home/fstummer/anaconda3/lib may be
hidden by files in:
hidden by files in:
hidden by files in:
source/visualization/OpenGL/CMakeLists.txt:18 (GEANT4_GLOBAL_LIBRARY_TARGET)
Anaconda is installed, which is why the files are sometimes found twice in different folders.
I used the following gcc and cmake versions:
gcc (crosstool-NG 1.24.0.131_87df0e6_dirty) 7.5.0
cmake version 3.16.3
When I run make, after 81% are finished, I get the following error:
[ 81%] Building CXX object source/interfaces/CMakeFiles/G4interfaces.dir/basic/src/G4UIXm.cc.o
/home/fstummer/geant4.10.04.p03/source/interfaces/basic/src/G4UIXm.cc:43:10: fatal error: Xm/Xm.h: No such file or directory
#include <Xm/Xm.h>
compilation terminated.
make[2]: *** [source/interfaces/CMakeFiles/G4interfaces.dir/build.make:197: source/interfaces/CMakeFiles/G4interfaces.dir/basic/src/G4UIXm.cc.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:4226: source/interfaces/CMakeFiles/G4interfaces.dir/all] Error 2
make: *** [Makefile:152: all] Error 2
In the Geant4-Installation guide I found that this header needs to be in MOTIF_INCLUDE_DIR, which is set to /usr/include and Xm/Xm.h is actually there. The following lines show how motif and opengl variables are set right now:
GEANT4_USE_XM ON
MOTIF_INCLUDE_DIR /usr/include
MOTIF_LIBRARIES /usr/lib/x86_64-linux-gnu/libXm.so
OPENGL_EGL_INCLUDE_DIR /usr/include
OPENGL_GLX_INCLUDE_DIR /usr/include
OPENGL_INCLUDE_DIR /usr/include
OPENGL_egl_LIBRARY /usr/lib/x86_64-linux-gnu/libEGL.so
OPENGL_gl_LIBRARY /usr/lib/x86_64-linux-gnu/libGL.so
OPENGL_glu_LIBRARY /usr/lib/x86_64-linux-gnu/libGLU.so
OPENGL_glx_LIBRARY /usr/lib/x86_64-linux-gnu/libGLX.so
OPENGL_opengl_LIBRARY /usr/lib/x86_64-linux-gnu/libOpenGL.so
OPENGL_xmesa_INCLUDE_DIR
What can I do about this error?
