I am in the process of building my GEANT4 and I already did the cmake with the options GEANT4_INSTALL_DATA, GEANT4_USE_QT,GEANT4_USE_OPENGL_X11, GEANT4_USE_XM on. Now I did the make -jN and have the following error:
[ 9%] Building CXX object source/geometry/CMakeFiles/G4geometry.dir/magneticfield/src/G4FieldManagerStore.cc.o
/home/ggarcia/path/to/geant4.10.06/source/geometry/magneticfield/src/G4FieldManagerStore.cc: In static member function ‘static void G4FieldManagerStore::DeRegister(G4FieldManager*)’:
/home/ggarcia/path/to/geant4.10.06/source/geometry/magneticfield/src/G4FieldManagerStore.cc:119:31: error: no matching function for call to ‘G4FieldManagerStore::erase(__gnu_cxx::__normal_iterator<G4FieldManager* const*, std::vector<G4FieldManager*> >&)’
GetInstance()->erase(i);
/home/ggarcia/path/to/geant4.10.06/source/geometry/magneticfield/src/G4FieldManagerStore.cc:119:31: note: candidates are:
In file included from /usr/include/c++/4.8.2/vector:69:0,
from /home/ggarcia/path/to/geant4.10.06/source/geometry/magneticfield/include/G4FieldManagerStore.hh:45,
from /home/ggarcia/path/to/geant4.10.06/source/geometry/magneticfield/src/G4FieldManagerStore.cc:32:
/usr/include/c++/4.8.2/bits/vector.tcc:134:5: note: std::vector<_Tp, _Alloc>::iterator std::vector<_Tp, _Alloc>::erase(std::vector<_Tp, _Alloc>::iterator) [with _Tp = G4FieldManager*; _Alloc = std::allocator<G4FieldManager*>; std::vector<_Tp, _Alloc>::iterator = __gnu_cxx::__normal_iterator<G4FieldManager**, std::vector<G4FieldManager*> >; typename std::_Vector_base<_Tp, _Alloc>::pointer = G4FieldManager**]
/usr/include/c++/4.8.2/bits/vector.tcc:134:5: note: no known conversion for argument 1 from ‘__gnu_cxx::__normal_iterator<G4FieldManager* const*, std::vector<G4FieldManager*> >’ to ‘std::vector<G4FieldManager*>::iterator {aka __gnu_cxx::__normal_iterator<G4FieldManager**, std::vector<G4FieldManager*> >}’
/usr/include/c++/4.8.2/bits/vector.tcc:146:5: note: std::vector<_Tp, _Alloc>::iterator std::vector<_Tp, _Alloc>::erase(std::vector<_Tp, _Alloc>::iterator, std::vector<_Tp, _Alloc>::iterator) [with _Tp = G4FieldManager*; _Alloc = std::allocator<G4FieldManager*>; std::vector<_Tp, _Alloc>::iterator = __gnu_cxx::__normal_iterator<G4FieldManager**, std::vector<G4FieldManager*> >; typename std::_Vector_base<_Tp, _Alloc>::pointer = G4FieldManager**]
/usr/include/c++/4.8.2/bits/vector.tcc:146:5: note: candidate expects 2 arguments, 1 provided
make[2]: *** [source/geometry/CMakeFiles/G4geometry.dir/magneticfield/src/G4FieldManagerStore.cc.o] Error 1
make[1]: *** [source/geometry/CMakeFiles/G4geometry.dir/all] Error 2
make: *** [all] Error 2
I am very newbie with the Linux and also the building process, so any answer should have a lot of explanation so I could understand.
Many thanks for your help.
