I have been exploring the extended/medical/DICOM example in order to import a CT of a phantom into my Geant4 geometry.
But my goal is to manipulate the imported DICOM geometry, by changing the material or density of a certain volume of interest. I thought of using the partial phantom option, but at a first glance it seems quite difficult to perfectly localize and overlap my voxels in the VOI with the G4 volume I would create. I also thought of manipulating the .g4dcm files myself and changing the voxels of the VOI to the material and density I am interested in, but I don’t fully understand the content of the .g4dcm files, especially the lines corresponding to the density values. How could I identify the voxels belonging to my VOI?
Perhaps there is a more direct solution. I’m looking forward to any input or suggestion you can give me, or at least shed some light on the density lines of the .g4dcm files.
You can see in DicomHandler::StoreData( that columns are written before rows:
for(G4int ww = 0; ww < fRows ;ww += fCompression ) {
for(G4int xx = 0; xx < fColumns ;xx +=fCompression ) {
But to get which voxels belong to VOI you need to write an algorithm to identify if a voxel is inside the VOI (center is inside the VOI? > 50% of voxel is inside the VOI, …), and Geant4 example does not do that. You would have to write the code or use one of the medical physics frameworks. I cannot tell you which one is better, but if you still prefer to use bare Geant4, I can point you to the code that one of these frameworks uses privately (pedro.arce@ciemat.es)
