Memory problem using process/em/setDirectionalSplitting
I want to simulate a X-ray tube, and improve it’s efficiency with biasing (dirctional bremsstrahlung splitting).
If I add the following commands into my run.mac file.
/process/em/setDirectionalSplitting true
/process/em/setDirectionalSplittingTarget 0 0 30 mm # x, y, z components of center
/process/em/setDirectionalSplittingRadius 6 mm
/process/em/setSecBiasing eBrem Target 50 300 keV # region, splitting factor, max energy
/process/em/setSecBiasing Rayl Target 50 300 keV
/process/em/setSecBiasing phot Target 50 300 keV
/process/em/setSecBiasing compt Target 50 300 keV
/process/em/setSecBiasing annihil Target 50 300 keV
The program would use more and more system memory gradually, fanally taking up all of the usable memory, leading to a “segmentation fault” or “Killed”.
I guess it’s because the program forget to delete the photons it do not want to track, leaving them wasting the memory (just like what I did when I tried to modify the UBS example to DBS).
Have anyone met the same problem before? How can I solve it? Or can I get to the people who’s in charge of this function?
Hi, this was fixed in Geant4 version 10.6. Are you using an earlier version? If so, could you please try 10.6.
Thank you so much. I forgot to mention the Geant4 version I use is 10.5. I’ll have a try, thanks a lot.
Can I ask about the PhysicsList used in this simulation,
Cheers
Sorry for a late reply.
EMPenelopePhsysics was used, because some articles shown that it’s a little more accurate than others in X-ray energy range, but, not for certain.
