Hello everyone.
I noticed that I can run multithreading using code like /run/numberOfThreads 4
and merge variable data we want using accumulableManager->Merge();
in examples/basic/B1.
But I’d like to output results as root files. I wonder if there is a related example in Geant4 that I can refer to?
Thanks!
you can have a look at, for instance, example basic/B4/B4a/
It creates a single root output file for both multi-threaded and single-threaded executions.
If you want to save root files from each thread, set
analysisManager->SetNtupleMerging(false);
in RunAction.cc
(line 57 with Geant4.11.0).
If you want to merge ntuples from multiple root files a posteriori
hadd -f B4.root B4_*
Cheers, Lorenzo
Thanks for your suggestion.
I successfully merged and output .root file using multithread, but I encountered a problem related to sensitive detector.
Here is my test example: GitHub - Peterllll/MT_test: multithread_test
Once when I using SD to get deposit energy like line 57 in EventAction.cc:
ergt1+=(*SDdet1)[i1]->GetEdep()/MeV
I’ll get an error like this:
*** Break *** segmentation violation
[1] 97640 segmentation fault (core dumped)
When I comment out line 57 and line 60 in EventAction.cc, the program will run normally.
Do I need to do some special adjustments for SD when using multithread?
Thanks!
Dear @hcy,
the SD is not one of those entities that needs to be modified when running in parallel compared to sequential mode.
This might actually be a simple c++ issue. Try simple debugging like checking for the pointer actually pointing somewhere and or the size of the hitscollection.
Cheers,
/Pico
Ok, I got it, appreciate your help. @pico
