Hi~
I constructed my model in GEANT4 via the gdml file, which is converted from a .stp file. However, I got the following messages when I run my program. I am not sure if it is caused by geometry errors. I have checked my .stp model and found it is okay. So I am wondering if someone can tell me the reason of these issues.
Besides, what influence would these messages make to my results? Thank you.
*** G4Exception : GeomNav0003
Stuck Track: potential geometry or navigation problem.
Track stuck, not moving for 25 steps
in volume -LV_VVport02-98_PV- at point (10672.4,887.587,-6569.55)
direction: (0.877659,-0.472255,-0.0817929).
*** Event Must Be Aborted ***
G4WT14 > G4Track (0x7f5db0c99d70) - track ID = 5, parent ID = 1
G4WT14 > Particle type : gamma - creator process : neutronInelastic, creator model : Undefined
G4WT14 > Kinetic energy : 941.076 keV - Momentum direction : (0.877659,-0.472255,-0.0817929)
G4WT14 > Step length : 1 Ang - total energy deposit : 0 eV
G4WT14 > Pre-step point : (10672.4,887.587,-6569.55) - Physical volume : LV_VVport02-98_PV (M105)
G4WT14 > - defined by : Transportation - step status : 1
G4WT14 > Post-step point : (10672.4,887.587,-6569.55) - Physical volume : LV_VVport02-98_PV (M105)
G4WT14 > - defined by : compt - step status : 7
G4WT14 > *** Note: Step information might not be properly updated.
G4WT14 >
