Messenger file, command not found
Hello, I created a messenger file, that should set the position of a surface by the command line
/Chamber20nep/DummySurfacePos 0 0 10 mm
I don’t get errors during the compiling, but when I run the simulation I get
***** COMMAND NOT FOUND </Chamber20nep/DummySurfacePos 0 0 10 mm> *****
I don’t understand what I’m wrong
Chamber20nepMessenger.cc (1.7 KB)
Chamber20nepMessenger.hh (576 Bytes)
Thanks
Do you instantiate the Chamber20nepMessenger class?
Hi @mkelsey
how and where should I instantiate it?
I call it in the Chamber20nep.cc
Chamber20nep::Chamber20nep()
chamber20NepMessenger = new Chamber20nepMessenger(this);
Chamber20nep::~Chamber20nep()
delete chamber20NepMessenger;
Chamber20nep.cc (3.4 KB)
Chamber20nep.hh (752 Bytes)
and when i compile, I see Chamber20nepMessenger files are processed
[ 10%] Building CXX object CMakeFiles/SimLuna.dir/src/Chamber20nepMessenger.cc.o
should I do something more to instantiate the class?
That’s exactly right. I guess that Chamber20nep is your detector construction class? Do you start running your macro commands before the DetectorConstruction has been created?
Hello @mkelsey
Chambe20nep is a piece of the full setup and it is called in the DetectorConstruction. Thanks to your suggestion to run the macro before detectorconstruction is created, I understood the problem. I had to get istance in the detector construction to make working the chamber messenger
DetectorConstruction::DetectorConstruction():G4VUserDetectorConstruction()
  detectorConstructionMessenger = new DetectorConstructionMessenger(this);
  materials = Materials::GetInstance();
  AGePD = GePD::GetInstance();
  AGeDD = GeDD::GetInstance();
  AChamber20nep = Chamber20nep::GetInstance();
