Messengers not updating geometry
Geometry and simulation work fine when adjusting parameters from the source code.
However, when updating geometries via UI messengers or batch code, it doesn’t work.
Below is an example of what it looks like upon the first run, with default parameters set in the source code.
Below is an example of the number of detector columns set to 5 (originally set to 10 in c++ code) via UI messenger commands, and then breaks.
Below is my construction.cc code, where I determine my messengers.
#include "construction.hh"
MyDetectorConstruction::MyDetectorConstruction()
    nCols = 10;
    nRows = 10;
    xWorld = 0.05*m;
    yWorld = 0.05*m;
    zWorld = 0.05*m;
    xRadiator1 = 0.02*m;
    yRadiator1 = 0.02*m;
    zRadiator1 = 0.0025*m;
    dRadiator1 = 0.03*m;
    xRadiator2 = 0.02*m;
    yRadiator2 = 0.02*m;
    zRadiator2 = 0.005*m;
    dRadiator2 = 0.007*m;
    xDet = 0.02*m;
    yDet = 0.02*m;
    mRadiator1 = 2; // 1 = water, 2 = aerogel
    mRadiator2 = 3; // 3 = glass
    mWorld = 4; // 4 = air
    xPixel = xDet/nRows;
    yPixel = yDet/nCols;
    zPixel = 0.001*m;
    dMessenger = new G4GenericMessenger(this, "/detector/", "Detector Construction");
    wMessenger = new G4GenericMessenger(this, "/world/", "World Construction");
    r1Messenger = new G4GenericMessenger(this, "/Radiator1/", "Radiator1 Construction");
    r2Messenger = new G4GenericMessenger(this, "/Radiator2/", "Radiator2 Construction");
    mMessenger = new G4GenericMessenger(this, "/materials/", "Materials");
    dMessenger->DeclareProperty("Columns", nCols, "Number of columns");
    dMessenger->DeclareProperty("Rows", nRows, "Number of rows");
    dMessenger->DeclareProperty("XDetector", xDet, "X length of detector");
    dMessenger->DeclareProperty("YDetector", yDet, "Y length of detector");
    wMessenger->DeclareProperty("xWorld", xWorld, "X length of world");
    wMessenger->DeclareProperty("yWorld", yWorld, "Y length of world");
    wMessenger->DeclareProperty("zWorld", zWorld, "Z length of world");
    r1Messenger->DeclareProperty("xRadiator1", xRadiator1, "X length of Radiator1");
    r1Messenger->DeclareProperty("yRadiator1", yRadiator1, "Y length of Radiator1");
    r1Messenger->DeclareProperty("zRadiator1", zRadiator1, "Z length of Radiator1");
    r1Messenger->DeclareProperty("dRadiator1", dRadiator1, "Distance from Radiator1 to detectors");
    r2Messenger->DeclareProperty("xRadiator2", xRadiator2, "X length of Radiator2");
    r2Messenger->DeclareProperty("yRadiator2", yRadiator2, "Y length of Radiator2");
    r2Messenger->DeclareProperty("zRadiator2", zRadiator2, "Z length of Radiator2");
    r2Messenger->DeclareProperty("dRadiator2", dRadiator2, "Distance from Radiator2 to detectors");
    mMessenger->DeclareProperty("mRadiator1", mRadiator1, "Radiator 1 material");
    mMessenger->DeclareProperty("mRadiator2", mRadiator2, "Radiator 2 material");
    mMessenger->DeclareProperty("mWorld", mWorld, "World material");
    DefineMaterials();
MyDetectorConstruction::~MyDetectorConstruction()
void MyDetectorConstruction::DefineMaterials()
    G4NistManager *nist = G4NistManager::Instance();  //the geant4 nist material database
	SiO2 = new G4Material("SiO2", 2.201*g/cm3, 2); //defining the silicone dioxide material object
	SiO2->AddElement(nist->FindOrBuildElement("Si"), 1);  //adding the silicone element to the object
	SiO2->AddElement(nist->FindOrBuildElement("O"), 2); //adding the oxygen element to the object
	H2O = new G4Material("H2O", 1.000*g/cm3, 2); //defining h20 material object
	H2O->AddElement(nist->FindOrBuildElement("H"), 2); //adding the hydrogen element to object
	H2O->AddElement(nist->FindOrBuildElement("O"), 1); //adding the oxygen element to object
	C = nist->FindOrBuildElement("C"); //creating the carbon material object
	B2O3 = new G4Material("B2O3", 2.46*g/cm3, 2);
	B2O3->AddElement(nist->FindOrBuildElement("B"), 2);
	B2O3->AddElement(nist->FindOrBuildElement("O"), 3);
	G4double energy[2] = {1.239841939*eV/0.9, 1.239841939*eV/0.2}; //momentum of photons usng conversion factor *eV / wavlength of red light and blue light
	G4double rindexAerogel[2] = {1.1, 1.1}; //refractive index of aerogel
	G4double rindexAir[2] = {1.0, 1.0}; //refractive index of the world volume (air)
	G4double rindexWater[2] = {1.333, 1.333}; //refractive index of the world volume (water)
	G4double rindexGlass[2] = {1.5, 1.5}; //refractive index of glass
    if(mRadiator1 == 1)
        radiatorMat1 = nist->FindOrBuildMaterial("G4_WATER"); //createing the radiator material (water)
	    mptRadiator1 = new G4MaterialPropertiesTable(); //creating properites object for water
	    mptRadiator1->AddProperty("RINDEX", energy, rindexWater, 2); //adding property to object
	    radiatorMat1->SetMaterialPropertiesTable(mptRadiator1); //assigning properties object to radiator material object
    if(mRadiator1 == 2)
        radiatorMat1 = new G4Material("Aerogel", 0.200*g/cm3, 3); //creating the aerogel material object
	    radiatorMat1->AddMaterial(SiO2, 62.5*perCent);  //adding the silione dioxide material to aerogel object
	    radiatorMat1->AddMaterial(H2O, 37.4*perCent);  //adding the h20 material to aergoel object
	    radiatorMat1->AddElement(C, 0.1*perCent);  //adding the carbon material to aerogel object
	    mptRadiator1 = new G4MaterialPropertiesTable(); //creating aerogel material properties object
	    mptRadiator1->AddProperty("RINDEX", energy, rindexAerogel, 2); //adding property to this object
	    radiatorMat1->SetMaterialPropertiesTable(mptRadiator1); //assigning the Aergoel object the properties from the previous object created
    if(mRadiator2 == 3)
        radiatorMat2 = new G4Material("Glass", 2.23*g/cm3,2);//Creating glass
	    radiatorMat2->AddMaterial(SiO2, 70*perCent);
	    radiatorMat2->AddMaterial(B2O3, 30*perCent);
	    mptRadiator2 = new G4MaterialPropertiesTable(); //Creating glass material properties table
        mptRadiator2->AddProperty("RINDEX", energy, rindexGlass, 2); //adding property to this object
	    radiatorMat2->SetMaterialPropertiesTable(mptRadiator2); //setting material properties
     if(mWorld == 4)
        worldMat = nist->FindOrBuildMaterial("G4_AIR"); //createing the world material (air)
	    mptWorld = new G4MaterialPropertiesTable(); //creating properites object for air
	    mptWorld->AddProperty("RINDEX", energy, rindexAir, 2); //adding property to object
	    worldMat->SetMaterialPropertiesTable(mptWorld); //assigning properties object to world material object
G4VPhysicalVolume *MyDetectorConstruction::Construct()
	G4Box *solidWorld = new G4Box("solidWorld", xWorld, yWorld, zWorld); //setting up world volume as a box
	G4LogicalVolume *logicWorld = new G4LogicalVolume(solidWorld, worldMat, "logicWorld"); //creating the world as dimensions from box and material
	G4VPhysicalVolume *physWorld = new G4PVPlacement(0, G4ThreeVector(0., 0., 0.), logicWorld, "physWorld", 0, false, 0, true); //placing the world into geant 4 sim
	G4Box *solidRadiator1 = new G4Box("solidRadiator1", xRadiator1, yRadiator1, zRadiator1); //setting the dimensions for the radiator
	G4LogicalVolume *logicRadiator1 = new G4LogicalVolume(solidRadiator1, radiatorMat1, "logicRadiator1"); //creating the aergoel radiator from dimensions
	G4VPhysicalVolume *physRadiator1 = new G4PVPlacement(0, G4ThreeVector(0., 0., zWorld-dRadiator1), logicRadiator1, "physRadiator1", logicWorld, false, 0, true); //placing radiator into world volume
	G4Box *solidRadiator2 = new G4Box("solidRadiator2", xRadiator2, yRadiator2, zRadiator2); //setting dimensions of glass radiator
	G4LogicalVolume *logicRadiator2 = new G4LogicalVolume(solidRadiator2, radiatorMat2, "logicRadiator2");
	G4VPhysicalVolume *physRadiator2 = new G4PVPlacement(0, G4ThreeVector(0., 0., zWorld-dRadiator2), logicRadiator2, "physRadiator2", logicWorld, false, 0, true);
	G4Box *solidDetector = new G4Box("solidDetector", xPixel, yPixel, zPixel);  //setting the dimensions for the detectors
	logicDetector = new G4LogicalVolume(solidDetector, worldMat, "logicDetector"); //creating the detectors, with same material as world
	for(G4int i = 0; i < nRows; i++)
		for(G4int j = 0; j <nCols; j++)
		    posX = -xDet+(i*2*xDet/nRows) + xDet/nRows;
		    posY = -yDet+(j*2*yDet/nCols) + yDet/nCols;
		    posZ = zWorld - zPixel;
			physDetector= new G4PVPlacement(0, G4ThreeVector(posX, posY, posZ), logicDetector, "physDetector", logicWorld, false, j+i*nCols, true); //placing detectors into the world
			G4cout << posX << posY << posZ << G4endl;
	return physWorld; //returning the world, including everything inside
void MyDetectorConstruction::ConstructSDandField()
    MySensitiveDetector *sensDet = new MySensitiveDetector("SensitiveDetector"); //creating a sensitive detector object
    if(logicDetector != NULL)
       logicDetector->SetSensitiveDetector(sensDet); //assigning the detectors as senstive detectors (it generates a hit when a track traverses its volume)
Do you have a runManager->Initialize() embedded in your main()? If so, then the geometry is getting built before you change any of the parameters.
If you change the geometry parameters via macro, then you should also call runManager->GeometryHasBeenModified(), which will trigger the Run Manager to rebuild it (with your new values). I am not familiar with how to do this via G4GenericMessenger, but I would expect there to be examples that show it.
Hello thanks for getting back to me!
Yes I do have runManager->Initialize() in my main()
Main simulation file embedded below:
#include <iostream>
#include "G4RunManager.hh"
#include "G4MTRunManager.hh"
#include "G4UImanager.hh"
#include "G4VisManager.hh"
#include "G4VisExecutive.hh"
#include "G4UIExecutive.hh"
#include "physics.hh"
#include "action.hh"
int main(int argc, char** argv)
	#ifdef G4MULTITHREADED
		G4MTRunManager *runManager = new G4MTRunManager();
	#else
    	G4RunManager *runManager = new G4RunManager();
	#endif
	runManager->SetUserInitialization(new MyDetectorConstruction());
	runManager->SetUserInitialization(new MyPhysicsList());
	runManager->SetUserInitialization(new MyActionInitialization());
	runManager->Initialize();
	G4UIExecutive  *ui = 0;
	if(argc == 1)
		ui = new G4UIExecutive(argc, argv);
	G4VisManager *visManager = new G4VisExecutive();
	visManager->Initialize();
	G4UImanager * UImanager = G4UImanager::GetUIpointer();
	if(ui)
		UImanager->ApplyCommand("/control/execute vis.mac");
		ui->SessionStart();
	else
		G4String fileName = argv[1];
		UImanager->ApplyCommand(command+fileName);
    return 0;
Where do I run the runManager->GeometryHasBeenModified() command?
below is my macro file where i am changing my parameters via the generic messengers I have created in my construction.cc file (this macro file is executed from my vis.mac macro file):
/run/reinitializeGeometry
/gun/particle mu+
/gun/energy 4 GeV
/world/xWorld 0.06
/world/yWorld 0.06
/world/zWorld 0.06
/detector/xDet 0.012
/detector/yDet 0.012
/detector/nCols 10
/detector/nRows 10
/Radiator1/xRadiator1 0.02
/Radiator1/yRadiator1 0.2
/Radiator1/zRadiator1 0.005
/Radiator1/dRadiator1 0.04
/materials/mRadiator1 2
/materials/mWorld 3
/run/geometryModified
/run/initialize
/run/beamOn 1
Am I changing the parameters correctly via the macro file method??
Okay. So your geometry is getting built with all of the default settings, before your macro commands are ever even seen. If you don’t mind modifying your macro, I would recommend the following:
  1. Remove runManager->Initialize() from your main().
  2. Add /run/initialize to your macro file immediately before /run/beamOn. That will happen after all your macro commands setting up the geometry.
An alternative is to add the call to runManager->GeometryHasBeenModified() to each of your macro commands. I don’t know how to do that; you’ll have to read the documentation.
I have adjusted my code so that now runManager->Initialize() has been removed from my main(), and inserted run/initialize before run/beamOn 1 in my macro file, after setting up all my parameters.
However, this didn’t work at first as then nothing was being built.
So I added run/initialize before setting up my parameters and after, and now it builds the new geometries, but with a few errors…
Firstly, the detectors are now not being built, and it says they are “overlapping with the mother volume” - I have checked the geometries and have no idea why this is happening.
Secondly, when I press the run beam, nothing is generated. I should see Cherenkov radiation through my 2 radiators but there is nothing.
Below is my updated macro file:
/run/initialize
/gun/particle mu+
/gun/energy 4 GeV
/world/xWorld 0.05
/world/yWorld 0.05
/world/zWorld 0.05
/detector/xDetector 0.02
/detector/yDetector 0.02
/detector/Columns 10
/detector/Rows 10
/Radiator1/yRadiator1 0.04
/Radiator1/dRadiator1 0.03
/Radiator2/xRadiator2 0.02
/Radiator2/yRadiator2 0.02
/Radiator2/zRadiator2 0.005
/Radiator2/dRadiator2 0.007
/materials/mWorld 3
/run/initialize
/run/beamOn 1
Below is my updated main() file:\
#include <iostream>
	#else
	#endif
	//runManager->Initialize();
	if(argc == 1)
	if(ui)
		ui->SessionStart();
	else
    return 0;
Below is my construction.cc file - where my geometries are being created:
    nCols = 10;
    nRows = 10;
    xWorld = 0.05*m;
    yWorld = 0.05*m;
    zWorld = 0.05*m;
    zRadiator1 = 0.005*m;
    xDet = 0.02*m;
    yDet = 0.02*m;
    zPixel = 0.001*m;
    dMessenger->DeclareProperty("xDetector", xDet, "X length of detector");
    dMessenger->DeclareProperty("yDetector", yDet, "Y length of detector");
    DefineMaterials();
    if(mRadiator1 == 1)
    if(mRadiator1 == 2)
    if(mRadiator2 == 3)
     if(mWorld == 4)
And not sure whether this will have any effect but, below is my vis.mac file, which sets all the visual properties of the simulation:
/vis/open OGL
/vis/viewer/set/viewpointVector 1 1 1
/vis/drawVolume
/vis/scene/add/scale 10 cm
/vis/scene/add/axes
/vis/scene/add/eventID
/control/execute set.mac
Any help would be appreciated!
Did you ever figure this out? I’m also having some issue with the geometry not updating after running ReinitializeGeometry() in the source file, or /run/reinitializeGeometry in a macro
Me too, Maybe this is a bug.
This is a snippet that works for me, maybe this helps?
The function is called via macro command in a messenger…
void DetectorConstruction::setRadius(G4double radius) {
    G4GeometryManager::GetInstance() -> OpenGeometry();
    //* example
    auto pipe = static_cast<G4Tubs*>(G4LogicalVolumeStore::GetInstance()->GetVolume("pipe")->GetSolid());
    pipe->SetOuterRadius(radius);
    G4RunManager::GetRunManager()->GeometryHasBeenModified();
    G4UImanager* UImanager = G4UImanager::GetUIpointer();
    if(UImanager->GetUIpointer()) {
        UImanager->ApplyCommand("/vis/viewer/rebuild");
I tried the two method, it did not work. Maybe this is reallly a bug.
When I use /run/reinitalizeGeometry, I’m usually visualizing my geometry, but I always have to use /run/initalize after reinitalizing for the geometry to update.
Hello all,
This still is a persistent issue for me I will re-paste my code for comparison.
I am trying to simulate 2 radiators and want a macro to adjust their sizes, thickness and distance from each other, as I simulate a muon through both.
    fMessenger = new G4GenericMessenger(this, "/radiator/", "Radiator Construction");
    fMessenger->DeclareProperty("thickness", thickness, "Z Thickness of radiators");
    fMessenger->DeclareProperty("size", size, "XY Size of radiators");
    fMessenger->DeclareProperty("distance", distance, "Distance between radiators");
    thickness = 0.01*m;
    size = 0.2*m;
    distance = 0.025*m;
Dear @jazminstewart
The basic course of Geant4 [1] explains how to implement this feature step by step, starting from scratch. Can you give it a try?
Thank you for your time
Best,
Alvaro
[1] First steps with Geant4 (15-19 April 2024): Overview · Indico
Did you success modifying geometry with messengers… i have same problem !! i check that new value of parameters are injected in the geometry…but can’t get a new visualization of the modified geometry when using /run/reinitializeGeometry
@montarou If I call the messenger setting on GUI with the macro commands as
/run/initialize
/run/beamOn 1
The messenger setting is implemented.
Ah, yes. Thank you, @rslu. Gerard @montarou posted another thread, to which there was this reply: How to modify a geometry using messengers in interactive mode - #12 by allison. There was the same conclusion - for a “minor change” (the second case), you need only change the geometry, then
/run/initialize
Of course, the user has to take care not to cause geometry overlaps.
I’m not sure why one has to initialize after reinitialize.
If I understand things correctly, the first line call DetectorConstruction::Construct() and sets the “geometryHasChanged” flag. The second line triggers all the other stuff like generating the material-cuts couples, cross-section tables, etc., which depend on the geometry.
By separating them, you could also have physics changes in between.
I am also experiencing this issue, using version 11.3.2. I have tried implementing all the suggestions throughout this thread and also this one, but nothing has worked.
