Does Geant4 provide some way to unite many physical volumes of the same material? Or is there a way to unite solid volumes other than using Boolean operations?
Please see Creating an Assembly of Volumes
You may want also to look at G4MultiUnion solid. It allows to unit disjoined solids, the only requirement is that they are associated to the same material.
Thank you very much for your answer. I believe I have found the answer I want. Thank you again
