Microyz Cmake and make
Geant4 Version:11.3.2
Operating System: Mac OS
In the module (microyz), if I want to modify the file plot.c. Should I change in build folder of microyz or in the source file? If I modify in build file, should I do cmake and make OR not?
Thanks
You should change in the source folder. The CMake/make step will copy the plot.C file from the source folder to the build folder and overwrite the plot.C file in your build directory.
I try to again build geant4.11.3.2. I got this during cmake.
Checking C++ feature CXXSTDLIB_FILESYSTEM_NATIVE - Success
CMake Error at cmake/Modules/G4OptionalComponents.cmake:42 (find_package):
Could not find a package configuration file provided by “CLHEP” (requested
version 2.4.6.0) with any of the following names:
 CLHEPConfig.cmake
 clhep-config.cmake
Add the installation prefix of “CLHEP” to CMAKE_PREFIX_PATH or set
“CLHEP_DIR” to a directory containing one of the above files. If “CLHEP”
provides a separate development package or SDK, be sure it has been
installed.
cmake/Modules/G4CMakeMain.cmake:59 (include)
CMakeLists.txt:49 (include)
Configuring incomplete, errors occurred!
Configure failed with the following output
CMake Version 4.2.1
Press [e] to exit screen
CLHEP_DIR CLHEP_DIR-NOTFOUND
CMAKE_BUILD_TYPE TestRelease
CMAKE_INSTALL_PREFIX /opt/geant4/11.3.2
CMAKE_OSX_ARCHITECTURES
CMAKE_OSX_DEPLOYMENT_TARGET
CMAKE_OSX_SYSROOT
GEANT4_BUILD_MULTITHREADED ON
GEANT4_INSTALL_DATADIR
GEANT4_USE_G3TOG4 OFF
GEANT4_USE_GDML OFF
GEANT4_USE_INVENTOR OFF
GEANT4_USE_INVENTOR_QT OFF
GEANT4_USE_OPENGL_X11 ON
GEANT4_USE_RAYTRACER_X11 OFF
GEANT4_USE_SYSTEM_CLHEP ON
GEANT4_USE_SYSTEM_EXPAT ON
GEANT4_USE_SYSTEM_ZLIB OFF
CLHEP_DIR: The directory containing a CMake configuration file for CLHEP.
Keys: [enter] Edit an entry [d] Delete an entry CMake Version 4.2.1
[l] Show log output [c] Configure
[h] Help [q] Quit without generating
[t] Toggle advanced mode (currently off)
sarahabdelaziz@Sarahs-MacBook-Pro ~ % ls
Desktop Library Pictures geant4
Documents Movies Public try1.C
Downloads Music data1.txt
sarahabdelaziz@Sarahs-MacBook-Pro ~ % cd geant4
sarahabdelaziz@Sarahs-MacBook-Pro geant4 % ls
build-11.3.2 geant4-v11.3.2
sarahabdelaziz@Sarahs-MacBook-Pro geant4 % cd build-11.3.2
sarahabdelaziz@Sarahs-MacBook-Pro build-11.3.2 % ccmake -DCMAKE_INSTALL_PREFIX=/opt/geant4/11.3.2 -DGEANT4_USE_QT=ON -DGEANT4_USE_QT_QT6=ON -DGEANT4_INSTALL_DATA=ON ../geant4-v11.3.2
What should I do? I press ON for clhep during configuration and this is what I get.
Also, should I write anything for the enviroment because due to delete geant4.11.3.0, I do not found ./zshrc file. What should I do, please? Because it is the third time to build this version and failed when I write root for microyz module but it is effected so use brew install root and then write error for mismatch clhep so delete it again.
If I press on Off for clhep , I got
– Checking C++ feature CXXSTDLIB_FILESYSTEM_NATIVE - Success
– Could NOT find WrapVulkanHeaders (missing: Vulkan_INCLUDE_DIR)
– Configuring download of missing dataset G4NDL (4.7.1)
– Configuring download of missing dataset G4EMLOW (8.6.1)
– Configuring download of missing dataset PhotonEvaporation (6.1)
– Configuring download of missing dataset RadioactiveDecay (6.1.2)
– Configuring download of missing dataset G4PARTICLEXS (4.1)
– Configuring download of missing dataset G4PII (1.3)
– Configuring download of missing dataset RealSurface (2.2)
– Configuring download of missing dataset G4SAIDDATA (2.0)
– Configuring download of missing dataset G4ABLA (3.3)
– Configuring download of missing dataset G4INCL (1.2)
– Configuring download of missing dataset G4ENSDFSTATE (3.0)
– Configuring download of missing dataset G4CHANNELING (1.0)
– The following Geant4 features are enabled:
CMAKE_CXX_STANDARD: Compiling against C++ Standard ‘17’
GEANT4_BUILD_MULTITHREADED: Build multithread enabled libraries
GEANT4_BUILD_TLS_MODEL: Building with TLS model ‘initial-exec’
GEANT4_USE_OPENGL_X11: Build Geant4 OpenGL driver with X11 support
GEANT4_USE_QT: Build Geant4 with Qt6 support
GEANT4_USE_QT3D: Build Geant4 Qt3D driver
– Configuring done (1.9s)
– Generating done (0.8s)
– Build files have been written to: /Users/sarahabdelaziz/geant4/build-11.3.2
Should I press On or Off?
