Mismatch Between Inverse Kinematics Neutron Data (ORSAY) and COM-Converted Direct Kinematics Simulation for the 7 Li(p,n) 7 Be Reaction
Geant4 Version: geant4-v11.3.0
Operating System: ubuntu
I am writing to discuss an issue I am encountering in my simulation study of the 7Li(p,n)7Be^7\mathrm{Li}(p,n)^7\mathrm{Be}7Li(p,n)7Be reaction. I have performed simulations using the physics list G4HadronPhysicsQGSP_BIC_AllHP along with G4IonPhysicsPHP for a proton beam energy of 2.13 MeV.
Subsequently, I converted the neutron data obtained from direct kinematics into inverse kinematics, ensuring the same center-of-mass (COM) energy and adopting the same N_t N_\phi normalization as implemented in the ORSAY experiment. However, I observe that the neutron counts in the angular distribution are lower than those reported in the ORSAY experimental results, which were obtained using inverse kinematics for the p(7Li,7Be)np(^7\mathrm{Li},^7\mathrm{Be})np(7Li,7Be)n reaction.
In the ORSAY experiment, a 15 MeV 7Li^7\mathrm{Li}7Li beam was incident on a polypropylene (proton) target. Since the cross-section in the center-of-mass frame should be invariant between direct and inverse kinematics, I would expect the converted angular distributions to show reasonable agreement. However, a clear discrepancy persists, particularly in the count rates.
I would be grateful if you could suggest possible reasons for this mismatch. Any guidance or insight on this matter would be extremely helpful in improving the accuracy of my analysis.
G4HadronPhysicsQGSP_BIC_AllHP uses particleHP models. Cross sections are taking from the TENDL library, which uses the ENDF data where available. These databases do not have channel by channel XS but only total particle yields (from any channel). If your data is more precise and you want to repleace the data in these databases I can provide you a simple code to do it. Contact me at pedro.arce@ciemat.es
