I am having trouble with the G4TENDL1.3.2 (and G4NDL4.6) database. I am trying to simulate where neutron induced activity ends up in the surrounding walls near the target chamber. The main reaction used is the p+18O-> 18F+n reaction at 18 MeV. I am using the QGSP_BIC_AllHP physics package with Geant4.10.6. However the cross section data for the nuclei 18O,17O and 16O seem to be missing from the TENDL dataset.
So if I am using the STCyclotron example from advanced examples with the target modified to 98.3% of 18O, 0.7 of 17O and 1% of 16O with the G4PROTONHPDATA pointing to /TENDL1.3.2/Proton and the G4NEUTRONHPDATA pointing to /G4NDL4.5. the program will run and use the wrong cross sections. When initiating the run the following shows up:
NeutronHP: 4TENDL1.3.2/Proton/Inelastic file for Z = 8, A = 10 is not found and NeutronHP will use /home/aton3/joaslott/Geant4/source/geant4.10.06-install/share/Geant4-10.6.0/data/G4TENDL1.3.2/Proton/Inelastic/CrossSection/8_16_Oxygen
NeutronHP: 4TENDL1.3.2/Proton/Inelastic file for Z = 8, A = 9 is not found and NeutronHP will use /home/aton3/joaslott/Geant4/source/geant4.10.06-install/share/Geant4-10.6.0/data/G4TENDL1.3.2/Proton/Inelastic/CrossSection/8_16_Oxygen
NeutronHP: 4TENDL1.3.2/Proton/Inelastic file for Z = 8, A = 8 is not found and NeutronHP will use /home/aton3/joaslott/Geant4/source/geant4.10.06-install/share/Geant4-10.6.0/data/G4TENDL1.3.2/Proton/Inelastic/CrossSection/8_16_Oxygen
@@@ G4ParticleHPInelastic instantiated for particle proton data directory variable is G4PROTONHPDATA pointing to /home/aton3/joaslott/Geant4/source/geant4.10.06-install/share/Geant4-10.6.0/data/G4TENDL1.3.2/Proton/Inelastic
NeutronHP: /Capture file for Z = 8, A = 10 is not found and NeutronHP will use /home/aton3/joaslott/GEANT4/geant4.10.06-install/share/Geant4-10.6.0/data/G4NDL4.6/Capture/CrossSection/8_16_Oxygen
NeutronHP: /Elastic file for Z = 8, A = 10 is not found and NeutronHP will use /home/aton3/joaslott/GEANT4/geant4.10.06-install/share/Geant4-10.6.0/data/G4NDL4.6/Elastic/CrossSection/8_16_Oxygen
NeutronHP: /Inelastic file for Z = 8, A = 10 is not found and NeutronHP will use /home/aton3/joaslott/GEANT4/geant4.10.06-install/share/Geant4-10.6.0/data/G4NDL4.6/Inelastic/CrossSection/8_16_Oxygen
NeutronHP: /Capture file for Z = 8, A = 9 is not found and NeutronHP will use /home/aton3/joaslott/GEANT4/geant4.10.06-install/share/Geant4-10.6.0/data/G4NDL4.6/Capture/CrossSection/8_16_Oxygen
NeutronHP: /Elastic file for Z = 8, A = 9 is not found and NeutronHP will use /home/aton3/joaslott/GEANT4/geant4.10.06-install/share/Geant4-10.6.0/data/G4NDL4.6/Elastic/CrossSection/8_16_Oxygen
NeutronHP: /Inelastic file for Z = 8, A = 9 is not found and NeutronHP will use /home/aton3/joaslott/GEANT4/geant4.10.06-install/share/Geant4-10.6.0/data/G4NDL4.6/Inelastic/CrossSection/8_16_Oxygen
NeutronHP: /Capture file for Z = 8, A = 8 is not found and NeutronHP will use /home/aton3/joaslott/GEANT4/geant4.10.06-install/share/Geant4-10.6.0/data/G4NDL4.6/Capture/CrossSection/8_16_Oxygen
NeutronHP: /Elastic file for Z = 8, A = 8 is not found and NeutronHP will use /home/aton3/joaslott/GEANT4/geant4.10.06-install/share/Geant4-10.6.0/data/G4NDL4.6/Elastic/CrossSection/8_16_Oxygen
NeutronHP: /Inelastic file for Z = 8, A = 8 is not found and NeutronHP will use /home/aton3/joaslott/GEANT4/geant4.10.06-install/share/Geant4-10.6.0/data/G4NDL4.6/Inelastic/CrossSection/8_16_Oxygen
Litterature suggests that the TENDL database seems to be the right way to go with the 18O(p,n)18F reaction at 17-18 MeV. At least for older versions. I am therefore hesitant to change to other data sets.
Any advice on how to proceed?
Thank you for your time.
