Modeling a curved tube following path
Hello.
I would like to model a tube following a path like plot3D(xv, yv, zv, tube_radius = r) of matplotlib.
I wonder is there any way to model a curved tube following a position vector ?
Thank you very much for your help in advance.
Something like this?
Yes exactly ! Is there any function to model like this ?
Take examples/basic/B1 from Geant4 sources and replace there DetectorConstruction.cc with the file in the attachment. The CreateCutTubsChain(...) function does what you need.
DetectorConstruction.cc (5.5 KB)
Very cool! So you create the “spiral” as a series of straight G4Tubs segments with the ends “beveled” to mostly match without overlap. I notice in Construct() that you place them as separate sibling volumes.
Would it make sense to integrate the segments into a G4MultiUnion solid? I think the two vectors of segments and transforms should be sufficient for that, but it’s not obvious to me what the cost/benefit tradeoff is.
We had a similar problem in CDMS, but we were dealing with curved segments (G4Torus, I think). That method made matching the end faces better, but it’s still not trivial.
Brilliant ! It works very well.
Thank you very much !
Usually I recommend to use Boolean solids only when really necessary. In case of a long “spiral”, like DNA, I believe that a set of separate G4CutTubs will perform better than G4MultiUnion solid. The segments can be moved all together by grouping them into G4AssemblyVolume.
