I am having issues altering the half-lives of nuclear excited states in Geant. I think the best way to illustrate my issue is through the rdecay01 example in 11.2.1. If I run the No252.mac file with no modifications, I get the appropriate mean life listed in the terminal output of the macro. However, this mean life (3.52 s) does not change even when I edit the UserData/UserEvapData_z102.a252 file, stored in the rdecay01 directory, to increase the half-life of the ground state. The terminal still gives the same mean life of 3.52 s. This is a general issue I am having with Geant, both with v11.2.1 and older versions. I seem unable to control the half-life of metastable states by editing the photon evaporation files. Are there any solutions here?
I am using that line, with the exception that the most recent version of Geant uses /process/had/rdm/ instead of /grdm/. I am referring to the following line in the rdecay01 example that comes with Geant:
When I try updating the UserEvapData_z102.a252 file, it has no effect on the code output.
The complete script is here:
# macro for rdecay01
# to read user's data file
/control/cout/ignoreThreadsExcept 0
# Set a very high time threshold to allow all decays to happen
/process/had/rdm/thresholdForVeryLongDecayTime 1.0e+60 year
/process/had/rdm/setPhotoEvaporationFile 102 252 ../UserData/UserEvapData_z102.a252
/gun/particle ion
/gun/ion 102 252 0 3.2070e+02
/run/beamOn 100000
RadioactiveDecay process needs not only RadioactiveDecay and PhotonEvaporation datasets, but also G4ENSDFSTATE.
In particular, timeLife of isotopes are read from G4ENSDFSTATE and there is no way for a user to change it, unless to modify directly G4ENSDFSTATE.
I my knowledge, yes.
You can ask details or confirmation directly to Alberto.Ribon@cern.ch or luis.sarmiento_pico@hep.lu.se or Vladimir.Ivantchenko@cern.ch
