Mpi parallel error for hpc system
Configuration
Geant4 Version:11.2.1
Operating System:Centos 7
Compiler/Version: openmpi 3.1.0 with gcc 10.2.1
CMake Version:3.25.3
Problem
  • One node: its ok!
  • two node:
    [cu02][[7230,1],52][btl_tcp_endpoint.c:625:mca_btl_tcp_endpoint_recv_connect_ack] received unexpected process identifier [[7230,1],100]
Scripts
#!/bin/bash
#PBS -N g4mpi_parallel_test
#PBS -l nodes=cu01:ppn=104+cu02:ppn=104
#PBS -l walltime=04:00:00
#PBS -o geant4_mpi_batch_scaling.out
#PBS -e geant4_mpi_batch_scaling.err
#PBS -q batch
#PBS -V
set -e
cd $PBS_O_WORKDIR
module purge
module load cmake/3.25.3
module load geant4/11.2.1/mpi-3.1.0
cmake -S . -B build
cmake --build build
cat $PBS_NODEFILE > hostfile
# test parallel
COMBINATIONS=(
    "1 52"
    "1 104"
    "2 52"
    "2 104"
# foreach core and thread
for combo in "${COMBINATIONS[@]}"; do
    read -r NODE CORE <<< "$combo"
    TOTAL_CORE=$(( NODE * CORE ))
    if [ "$CORE" -eq 52 ]; then
        BIND_OPTION="--bind-to core"
    else
        BIND_OPTION="--bind-to hwthread"
    fi
   echo "======== Testing: ${NODE} nodes × ${CORE} cores ========"
    LOGFILE="run_${NODE}n_${CORE}c.log"
    /usr/bin/time -v mpirun -np $TOTAL_CORE --map-by ppr:${CORE}:node:PE=1 $BIND_OPTION --hostfile hostfile --rank-by core build/exMPI01 build/run.mac > $LOGFILE 2>&1
    echo "======== ENDING: ${NODE} nodes  × ${CORE} core ========="
done
There’s been a major update to the MPI examples in the last few months and a preview will be available in the 11.4 Beta release at the end of June. I’d recommend migrating to this and trying this out when it’s released as this will be the implementation supported going forward.
