Geant4 Version: 11.2
Operating System: macOS Sonoma 14.4, M2
Compiler/Version: clang-1500.3.9.4
CMake Version: 3.28.0
I observed the following warning message when I enable HP physics in serial mode:
Exception: [code: system:22] caught: mutex lock failed: Invalid argument
Non-critical error: mutex lock failure in ~G4Cache<P15G4HadFinalState>.
If the RunManagerKernel has been deleted, it failed to delete an allocated resource
and this destructor is being called after the statics were destroyed.
I have a very small Geant4 application (80 lines of code) to reproduce this behavior:
# no problem:
$ PHYSLIST=QGSP_BERT G4RUN_MANAGER_TYPE=Serial ./build/mingle run.mac
# has problem:
$ PHYSLIST=QGSP_BERT_HP G4RUN_MANAGER_TYPE=Serial ./build/mingle run.mac
I reported this in another post. The discussion there is helpful but we did not pin down the real source of the error there.
