Multiple Outputs in Multithreading Mode
Hey,
I have been modifying the **ExampleB1** to calculating the Energy Deposit. I am writing the total Energy deposit to a ROOT File using the G4AnalysisManager. But when i use more number of threads, it creates more number of output files. For example, if run it on a single thread, then the output file is created as output.root, when i use 4 threads, 4 files are created: output_t0.root, output_t1.root,....output_t3.root its like a file for each thread. Is there any to fix it such that i can get a single output file
My codes can be accessed via this repository:
I am using Geant4 version 11.2.1 on windows 11 with visual studio compilers.
Thanks
Anantha Padmanabhan
I think that you should add some code in the runaction.
liking following
runaction::runaction()
analysisManager->SetNtupleMerging(true);
Thank you for your response. I found out that you can also use the hadd target_name.root output_t{0..n}.root command from ROOT for this purpose.
Best
Anantha
