Multithreading cannot be enabled on the new M1 Macbook and macOS 11.0.1 (Compiler Apple Clang 12.0).
Log:
/Users/fermi/dev/geant4/geant4.10.06.p03/source/global/management/src/G4ios.cc:44:53: error:
initializer for thread-local variable must be a constant expression
G4ThreadLocalStatic G4strstreambuf* _instance = new G4strstreambuf();
/Users/fermi/dev/geant4/geant4.10.06.p03/source/global/management/src/G4ios.cc:44:41: note:
use ‘thread_local’ to allow this
/Users/fermi/dev/geant4/geant4.10.06.p03/source/global/management/src/G4ios.cc:50:53: error:
/Users/fermi/dev/geant4/geant4.10.06.p03/source/global/management/src/G4ios.cc:50:41: note:
/Users/fermi/dev/geant4/geant4.10.06.p03/source/global/management/src/G4ios.cc:56:51: error:
…std::ostream* _instance = new std::ostream(_G4coutbuf_p());
/Users/fermi/dev/geant4/geant4.10.06.p03/source/global/management/src/G4ios.cc:56:39: note:
G4ThreadLocalStatic std::ostream* _instance = new std::ostream(_G4co…
/Users/fermi/dev/geant4/geant4.10.06.p03/source/global/management/src/G4ios.cc:62:51: error:
…std::ostream* _instance = new std::ostream(_G4cerrbuf_p());
/Users/fermi/dev/geant4/geant4.10.06.p03/source/global/management/src/G4ios.cc:62:39: note:
G4ThreadLocalStatic std::ostream* _instance = new std::ostream(_G4ce…
Can you try removing && defined(__x86_64__) from the definitions included in the file:
source/global/management/include/tls.hh
and see if that fixes the problem?
Note however that the new Apple Silicon architectures are not yet supported (and won’t be supported in past releases of Geant4).
It seems like you’re problem got solved, but I’m currently trying to set up Geant4 on a new M1-chipped macbook air; have you been able to get visualizations (via OGL, QT, or otherwise) to work so far? If so, what software are you using to visualize?
How’s your examples work? I installed Geant4 on M1 but all the basic examples tell me that its files “building for macos-x86_64 but attempting to link with file built for unknown64”.
Did you install all the required libraries through brew? If you do not specify the arch__x86 prefix, then all libraries are installed in the arm64 architecture, including cmake and Qt.
Sorry but I’m not so sure about how to add G4ENSDFSTATEDATA environment variable into my bash_profile. I tried the command in the figure you had post, but nothing happened, should I restart after the write?
Write the command into bash_profile just to avoid repeating the above command every time you restart the terminal. If you execute it manually, the Geant4 program can also run correctly.
Make sure you are using bash Shell instead of zsh then use the ‘open ~/.bash_profile’ command and write the above command.After all these are completed, you only need to restart your terminal.
Thank you very much, I have successfully installed Geant4 and ran the exampleB1. Everything works fine and I’m going to write my experience to file and post it on Github. I hope this would help other people stuck like me.
