Hello everyone,
In my application I am trying to build a bundle of scintillating fibers with SiPM matrices at each end. The simulation works fine when run in singlethreaded mode, but I wanted to adapt it to run it multithreaded to save time on simulation runs. I adapted the run manager and action initialization classes for multithreaded, but when running the simulation I get the following error:
Geant4 version Name: geant4-11-02-patch-01 [MT] (16-February-2024)
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
[1] 30149 IOT instruction (core dumped) ./sim gpsSr.mac
while trying to run it using the following macro:
/run/numberOfThreads 16
/run/initialize
/process/had/rdm/thresholdForVeryLongDecayTime 1.0e+60 year
/gps/particle ion
/gps/ion 38 90 0 0
/gps/pos/type Volume
/gps/pos/shape Cylinder
/gps/pos/centre 0. 0. 12. cm
/gps/pos/radius 0.8 cm
/gps/pos/halfz 6. cm
/gps/ang/type iso
/run/beamOn 100
I am new to multithreading, so I do not know if this is caused by faulty construction of the geometry, or if it’s something caused in the main simulation file. I will attach the sim.cc and the construction.cc responsible for the geometry.
#include <iostream>
#include "G4RunManager.hh"
#include "G4UIExecutive.hh"
#include "G4VisManager.hh"
#include "G4VisExecutive.hh"
#include "G4UImanager.hh"
#include "G4MTRunManager.hh"
#include "construction.hh"
#include "physics.hh"
#include "action.hh"
int main(int argc, char** argv) {
#ifdef G4MULTITHREADED
G4MTRunManager *runManager = new G4MTRunManager();
#else
G4RunManager *runManager = new G4RunManager();
#endif
runManager->SetUserInitialization(new myDetectorConstruction());
runManager->SetUserInitialization(new myPhysicsList());
runManager->SetUserInitialization(new myActionInitialization());
G4UIExecutive *uiExec = 0;
if(argc == 1) {
uiExec = new G4UIExecutive(argc, argv);
G4VisManager *visManager = new G4VisExecutive();
visManager->Initialise();
G4UImanager *uiManager = G4UImanager::GetUIpointer();
if(uiExec) {
uiManager->ApplyCommand("/control/execute vis.mac");
uiExec->SessionStart();
else {
G4String fileName = argv[1];
uiManager->ApplyCommand(command+fileName);
return 0;
myDetectorConstruction::myDetectorConstruction() {
xWorld = 0.5*m;
yWorld = 0.5*m;
zWorld = 0.5*m;
nCols = 8;
nRows = 8;
DefineMaterial();
myDetectorConstruction::~myDetectorConstruction() {
G4LogicalVolume *myDetectorConstruction::GetScoringVolume() const {
return fScoringVolume;
void myDetectorConstruction::DefineMaterial() {
G4NistManager *nist = G4NistManager::Instance();
std::vector<G4double> energy = {1.239841939*eV/0.9, 1.239841939*eV/0.2};
// Defining the world material
worldMat = nist->FindOrBuildMaterial("G4_AIR");
G4MaterialPropertiesTable *mptWorld = new G4MaterialPropertiesTable();
std::vector<G4double> rindexAir = {1.0, 1.0};
mptWorld->AddProperty("RINDEX", energy, rindexAir);
worldMat->SetMaterialPropertiesTable(mptWorld);
// Defining the scintillator material
detMat = new G4Material("detMat", 1.06*g/cm3, 2);
detMat->AddElement(nist->FindOrBuildElement("C"), 50.00*perCent);
detMat->AddElement(nist->FindOrBuildElement("H"), 50.00*perCent);
std::vector<G4double> scintEnergydetMat = {1.239841939*eV/0.9, 1.239841939*eV/0.425, 1.239841939*eV/0.2};
std::vector<G4double> rindexdetMat = {1.60, 1.60, 1.60};
std::vector<G4double> scintFracdetMat = {0.01, 1.0, 0.01};
G4MaterialPropertiesTable *mptdetMat = new G4MaterialPropertiesTable();
mptdetMat->AddProperty("RINDEX", scintEnergydetMat, rindexdetMat);
mptdetMat->AddProperty("SCINTILLATIONCOMPONENT1", scintEnergydetMat, scintFracdetMat);
mptdetMat->AddConstProperty("SCINTILLATIONYIELD", 10.44/keV);
mptdetMat->AddConstProperty("RESOLUTIONSCALE", 1.0);
mptdetMat->AddConstProperty("SCINTILLATIONTIMECONSTANT1", 3.3*ns);
mptdetMat->AddConstProperty("SCINTILLATIONYIELD1", 1.);
detMat->SetMaterialPropertiesTable(mptdetMat);
// Defining the case material
caseMat = new G4Material("caseMat", 0.855*g/cm3, 2);
caseMat->AddElement(nist->FindOrBuildElement("C"), 33.33*perCent);
caseMat->AddElement(nist->FindOrBuildElement("H"), 66.67*perCent);
Si = nist->FindOrBuildMaterial("G4_Si");
void myDetectorConstruction::ConstructScintillator() {
G4double radScint = 0.5*mm, lenScint = 10.*cm, posScint = 12.*cm, sideSIPM = 0.5*mm, lenSIPM = 0.1*mm, widthCase = 0.25*cm;
// Constructing the scintillating fibers
solidScintillator = new G4Tubs("solidScintillator", 0.*cm, radScint, lenScint, 0.*deg, 360.*deg);
logicScintillator = new G4LogicalVolume(solidScintillator, detMat, "logicalScintillator");
for(G4int i = 0; i < nRows; i++) {
for(G4int j = 0; j < nCols; j++) {
physScintillator = new G4PVPlacement(0, G4ThreeVector(-radScint*nRows+(i+0.5)*mm, -radScint*nCols+(j+0.5)*mm, posScint), logicScintillator, "physScintillator", logicWorld, false, j+i*nCols, true);
// Constructing the SIPM matrices
solidSIPM = new G4Box("solidSIPM", sideSIPM, sideSIPM, lenSIPM);
logicSIPM = new G4LogicalVolume(solidSIPM, Si, "logicSIPM");
physSIPM1 = new G4PVPlacement(0, G4ThreeVector(-sideSIPM*nRows+(i+0.5)*mm, -sideSIPM*nCols+(j+0.5)*mm, posScint+lenScint+lenSIPM), logicSIPM, "physSIPM1", logicWorld, false, j+i*nCols, true);
physSIPM2 = new G4PVPlacement(0, G4ThreeVector(-sideSIPM*nRows+(i+0.5)*mm, -sideSIPM*nCols+(j+0.5)*mm, posScint-lenScint-lenSIPM), logicSIPM, "physSIPM2", logicWorld, false, j+i*nCols, true);
// Constructing the casing of the detector
auto *solidCase1 = new G4Box("solidCase1", nRows*radScint, widthCase, lenScint+2*lenSIPM);
G4LogicalVolume *logicCase1 = new G4LogicalVolume(solidCase1, caseMat, "logicalCase1");
G4VPhysicalVolume *physCase11 = new G4PVPlacement(0, G4ThreeVector(0., nCols*radScint+widthCase, posScint), logicCase1, "physCase11", logicWorld, false, 0, true);
G4VPhysicalVolume *physCase12 = new G4PVPlacement(0, G4ThreeVector(0., -nCols*radScint-widthCase, posScint), logicCase1, "physCase12", logicWorld, false, 0, true);
auto *solidCase2 = new G4Box("solidCase2", widthCase, nCols*radScint+2*widthCase, lenScint+2*lenSIPM);
G4LogicalVolume *logicCase2 = new G4LogicalVolume(solidCase2, caseMat, "logicalCase2");
G4VPhysicalVolume *physCase21 = new G4PVPlacement(0, G4ThreeVector(nRows*radScint+widthCase, 0., posScint), logicCase2, "physCase21", logicWorld, false, 0, true);
G4VPhysicalVolume *physCase22 = new G4PVPlacement(0, G4ThreeVector(-nRows*radScint-widthCase, 0., posScint), logicCase2, "physCase22", logicWorld, false, 0, true);
auto *solidCase3 = new G4Box("solidCase3", nRows*radScint+2*widthCase, nCols*radScint+2*widthCase, widthCase);
G4LogicalVolume *logicCase3 = new G4LogicalVolume(solidCase3, caseMat, "logicalCase3");
G4VPhysicalVolume *physCase31 = new G4PVPlacement(0, G4ThreeVector(0., 0., posScint-lenScint-2*lenSIPM-widthCase), logicCase3, "physCase31", logicWorld, false, 0, true);
G4VPhysicalVolume *physCase32 = new G4PVPlacement(0, G4ThreeVector(0., 0., posScint+lenScint+2*lenSIPM+widthCase), logicCase3, "physCase32", logicWorld, false, 0, true);
fScoringVolume = logicScintillator;
G4VPhysicalVolume *myDetectorConstruction::Construct() {
solidWorld = new G4Box("solidWorld", xWorld, yWorld, zWorld);
logicWorld = new G4LogicalVolume(solidWorld, worldMat, "logicWorld");
physWorld = new G4PVPlacement(0, G4ThreeVector(0., 0., 0.), logicWorld, "physWorld", 0, false, 0, true);
ConstructScintillator();
return physWorld;
void myDetectorConstruction::ConstructSDandField() {
mySensitiveDetector *sensDet = new mySensitiveDetector("SensitiveDetector");
logicScintillator->SetSensitiveDetector(sensDet);
I am running GEANT4 MT version 11.2.1 on Ubuntu. The singlethreaded version is 11.2.0 and works fine, as mentioned above. Thank you in advance!
