I’m new to Geant4 and currently trying to simulate neutrons using the GPS macro in Geant4, but I’ve encountered an issue when running my simulation. Specifically, after selecting the physics list for neutrons and executing beamOn, the program crashes with a “core dumped” error.
Could anyone kindly point me in the right direction or share advice on how to resolve this issue? Any help would be greatly appreciated.
this is my physicsList
include “physics.hh”
//define constructor
MyPhysicsList::MyPhysicsList()
//define physics
RegisterPhysics (new G4EmStandardPhysics());
RegisterPhysics (new G4OpticalPhysics());
//define physics of decay for radioactive source
RegisterPhysics (new G4DecayPhysics()); //handle particle decays
RegisterPhysics (new G4RadioactiveDecayPhysics());
RegisterPhysics (new G4HadronElasticPhysicsHP());
RegisterPhysics (new G4HadronPhysicsQGSP_BERT_HP());
G4double CutValue = 0.1*um;
SetCutValue(CutValue, "gamma");
MyPhysicsList::~MyPhysicsList()
GPS macro in which i define neutron
/gps/particle neutron
/gps/ene/mono 10000 keV
/gps/pos/type Point
/gps/ang/type iso
/gps/pos/centre 0. 0. 16. mm
vis.mac file
/run/initialize
/vis/open OGLI
/vis/verbose errors
/vis/drawVolume
/vis/viewer/set/rotationStyle freeRotation
/vis/modeling/trajectories/drawByCharge-0/default/setDrawStepPts false
/vis/modeling/trajectories/drawByCharge-0/default/setStepPtsSize 1
(if too many tracks cause core dump => /tracking/storeTrajectory 0)
/vis/scene/add/axes
/vis/scene/add/scale
/vis/scene/add/eventID
/vis/modeling/trajectories/create/drawByParticleID
/vis/modeling/trajectories/drawByParticleID-0/set e- red
/vis/modeling/trajectories/drawByParticleID-0/set gamma green
/vis/modeling/trajectories/drawByParticleID-0/set neutron yellow
/vis/modeling/trajectories/drawByParticleID-0/set alpha blue
/vis/modeling/trajectories/drawByParticleID-0/set GenericIon blue
/vis/scene/endOfEventAction accumulate 10
/vis/verbose warnings
/control/execute gps.mac
and this is what I’m getting
G4ParticleHPNames: There are no data available for some isotopes in this material
G4ParticleHPNames: nor are there data for nearby isotopes.
G4ParticleHPNames: Please make sure G4NEUTRONHPDATA points to the directory
G4ParticleHPNames: in which the neutron scattering data are located.
G4ParticleHPNames: The material was A = 71, Z = 31
*** G4Exception : hadhp01
issued by : G4ParticleHPName::Init(…)
Data for Z=31 A=71 M=0 does not exist in G4NEUTRONHPDATA
G4ParticleHPNames: The material was A = 69, Z = 31
Data for Z=31 A=69 M=0 does not exist in G4NEUTRONHPDATA
====== ParticleHP Physics Parameters ========
Use only photo-evaporation 0
Skip missing isotopes 0
Neglect Doppler 0
Do not adjust final state 0
Produce fission fragments 0
Use WendtFissionModel 0
Use NRESP71Model 0
Use DBRC 0
PHP use Poisson 0
PHP check 1
CHECK HP NAMES 0
Enable DEBUG 0
msc: for pi+ SubType= 10
===== EM models for the G4Region DefaultRegionForTheWorld ======
WentzelVIUni : Emin= 0 eV Emax= 100 TeV Nbins=84 100 eV - 100 TeV
StepLim=Minimal Rfact=0.2 Gfact=2.5 Sfact=0.6 DispFlag:0 Skin=1 Llim=1 mm
hIoni: for pi+ XStype:3 SubType=2
dE/dx and range tables from 100 eV to 100 TeV in 84 bins
Lambda tables from threshold to 100 TeV, 7 bins/decade, spline: 1
StepFunction=(0.2, 0.1 mm), integ: 3, fluct: 1, linLossLim= 0.01
Bragg : Emin= 0 eV Emax=297.505 keV
BetheBloch : Emin=297.505 keV Emax= 100 TeV
hBrems: for pi+ XStype:1 SubType=3
hBrem : Emin= 0 eV Emax= 100 TeV ModifiedMephi
hPairProd: for pi+ XStype:1 SubType=4
Sampling table 20x1001; from 1.11656 GeV to 100 TeV
hPairProd : Emin= 0 eV Emax= 100 TeV ModifiedMephi
CoulombScat: for pi+ XStype:1 SubType=1 BuildTable=1
Lambda table from threshold to 100 TeV, 7 bins/decade, spline: 0
ThetaMin(p) < Theta(degree) < 180, pLimit(GeV^1)= 0.139531
eCoulombScattering : Emin= 0 eV Emax= 100 TeV
msc: for pi- SubType= 10
hIoni: for pi- XStype:3 SubType=2
ICRU73QO : Emin= 0 eV Emax=297.505 keV
hBrems: for pi- XStype:1 SubType=3
hPairProd: for pi- XStype:1 SubType=4
CoulombScat: for pi- XStype:1 SubType=1 BuildTable=1
Used Lambda table of pi+
