NeutronHP warning for wrong isotope in text geometry definition
Hi, I’m trying to simulation the a CLYC thermal neutron detector with text geometry. I define Li6 and Li7 like this, with 0.1eV neutron, and physics list QGSP_BERT_HP.
:ISOT Li6 3 3 6
:ISOT Li7 3 4 7
I believe this is right according to https://geant4.web.cern.ch/collaboration/working_groups/persistency/docs/textgeom.pdf, which tell me the syntax is :ISOT NAME Z N A.
But warinings for wrong isotope Li3, Li4 were shown.
NeutronHP: /Elastic file for Z = 3, A = 3 is not found and NeutronHP will use /home/wqd/soft/geant4/geant4-v11.2.2-install/share/Geant4/data/G4NDL4.7.1/Elastic/CrossSection/3_6_Lithium
NeutronHP: /Elastic file for Z = 3, A = 4 is not found and NeutronHP will use /home/wqd/soft/geant4/geant4-v11.2.2-install/share/Geant4/data/G4NDL4.7.1/Elastic/CrossSection/3_6_Lithium
If I switch the definition to this one, the warning for Li disappeared.
// CLYC
:ISOT Li6 3 6 6
:ISOT Li7 3 7 7
Geant4 Version: geant4-11-02-patch-02 [MT]
Operating System: Debian GNU/Linux 12
Compiler/Version: g++ (Debian 12.2.0-14) 12.2.0
CMake Version: 3.30.4
I’ve moved this to the physics category as it looks like the materials/geometry are constructed correctly, but this is an issue with the use of the NeutronHP physics.
Yes, the geometry is right. The message is saying that Li3 file does not exist in database, likely because there is no experimental data.
Well, I think the warning suggests that the G4tgbVolumeMgr mistakenly regarded :ISOT Li6 3 3 6 to Li3, and regarded :ISOT Li6 3 6 6 to Li6.
This might be unrelated to physics, but be related to the implementation of G4tgbVolumeMgr.
You are right, it is a bug in the doc
:ISOT
• Name
• Z
• N
• A
while it should be
:ISOT
• Name
• atomic number (Z)
• mass number (A)
• atomic mass
