I apologise if this isn’t the right place to ask this…
When energy is deposited in a scintillator and scintillation light is produced, the amount of light depends on the particle type (e.g. alphas produce less light than gammas), because of something called nuclear recoil quenching (among other names). I want to know whether GEANT4 implements anything of this sort, whether implicitly or explicitly.
indeed you can simulate nuclear quenching in Geant4. You can either set the scintillator yield per particle type, or use the Birk’s law by providing the appropriate coefficients. You can take a look at the examples under extended/optical.
Would I be correct in assuming that if Birk’s constant is not provided, then Birk’s law is not followed and scintillation yield is just proportional to energy?
Also, this is perhaps not a GEANT4 question, but is the ‘quenching’ described by Birks’ law the same as the ‘nuclear recoil quenching factor’ (or whatever else it is called)? Nothing in the expression for Birks’ law really appears to be particle-dependent, but I may be confused.
This is correct. Yes, if the Birks constant is not provided, the scintillation yield is proportional to the deposited energy, possibly with different coefficients for different particles types. The relevant piece of code in G4Scintillation.cc is below (l. 322ff)
// The default linear scintillation process // Units: [# scintillation photons / MeV] MeanNumberOfPhotons = MPT->GetConstProperty(kSCINTILLATIONYIELD); // Birk's correction via fEmSaturation and specifying scintillation by // by particle type are physically mutually exclusive if (fEmSaturation) MeanNumberOfPhotons *= (fEmSaturation->VisibleEnergyDepositionAtAStep(&aStep)); else MeanNumberOfPhotons *= TotalEnergyDeposit; }
The Birk’s law accounts for different dE/dx, which I think it is appropriate to describe ionization by heavy ions.
I am not sure whether this is what you mean but when an ion is implanted on a sensitive material (silicon detector as a classic example) when it does a particle decay, say alpha, the energy deposited in the material is not the energy of the alpha particle but rather the full q-value of the decay.
HOWEVER… even with a detector which uses calibration with internal sources (to account for the lack of ‘incoming’ dead layer) the measured energy is never the same as the expected full Q-value.
It is my understanding that due to many things but mostly to recombination of charges there is a “factor” (A dependent) between the energy measured and the energy deposited.
I have heard many names for this effect. Maybe this is what you mean.
Hi, Luis. I think what you’re describing is also what’s described by Lindhard theory – heavy ions, or “nuclear recoils” as we call them in CDMS, do not lose all of their kinetic energy to ionization. Some of their kinetic energy gets transferred directly to the solid material (lattice vibrations, a.k.a. phonons). The fraction of that non-ionizing deposit depends on the (A,Z) of both the projectile and target material, and also on the energy of the material.
Geant4 does model this. See TestEm7 and G4ScreenedNuclearRecoil.
