Null-pointer dereference in directional Compton splitting with G4EmLivermorePhysics
I found a reproducible segmentation fault when using directional secondary splitting for the Compton process.
Geant4 version: 11.4.2 (Also reproduced with 11.4.0)
Operating system: Ubuntu 24.04.3 LTS
Compiler: g++ (Ubuntu 13.3.0-6ubuntu2~24.04.1) 13.3.0
Physics constructor: G4EmLivermorePhysics
Primary particle: gamma
Energy range: 1–100 keV
Here is the biasing configuration used:
RegisterPhysics(new G4EmLivermorePhysics());
auto* parameters = G4EmParameters::Instance();
parameters->SetFluo(true);
parameters->SetAuger(true);
parameters->SetPixe(true);
parameters->SetDeexcitationIgnoreCut(true);
parameters->ActivateSecondaryBiasing(
    "compt", "SampleRegion", 1000, 1*MeV
parameters->SetDirectionalSplitting(true);
parameters->SetDirectionalSplittingTarget(targetPosition);
parameters->SetDirectionalSplittingRadius(targetRadius);
With directional splitting disabled, the simulation completes successfully. With directional Compton splitting enabled, it crashes inside G4EmBiasingManager::ApplyDirectionalSplitting(...).
GDB confirms that the temporary secondary vector contains a null pointer at the time of the crash:
kk = 1
k = 176
nsplit = 1000
tmpSecondaries.size() = 2
(gdb) p tmpSecondaries[kk]
$7 = (G4DynamicParticle *) 0x0
The null pointer is then dereferenced when the code evaluates tmpSecondaries[kk]->GetParticleDefinition().
To test a fix, I added a local check for the null pointer inside the ApplyDirectionalSplitting function in the Geant4 source code:
    for (std::size_t kk=0; kk<tmpSecondaries.size(); ++kk) {
        if(tmpSecondaries[kk]==nullptr){
          continue;
        if (tmpSecondaries[kk]->GetParticleDefinition() == theGamma) {
After rebuilding Geant4 11.4.2 with this change, the previously crashing simulation runs successfully with a Compton splitting factor of 1000.
Could you please confirm whether skipping null entries here is the correct fix, or if the null pointer is a symptom of an issue occurring earlier in the tracking process?
Thank you!
