Number of Sensitive detector and management of scoring
Hello to all ,
To map the doses, I created 1800 volumes. And I want to register them as a sensitive detector. But I don’t know why my simulation crashes at the 364th set of sensitive detector volumes (random number). Is there a maximum possible number of sensitive detectors created ?
Here is some informations :
(crash pic)
(Set SD)
And here is my Geometry , if you have any propositions to improve it, i’m open to your purposes :
Thank you
You seem to assign volumes to a single sensitive detector multiple times. Most possibly, you have the last assigned volume as a sensitive detector.
Also: Check you have enough elements in the array defined, and they are not null ptr.
yes i solved my problem thank you !
