I am trying to create a common development environment for my organization as a Docker image.
I have an image based on Ubuntu 22.02, with Geant4 11.1.1 built from source, with Qt, and OGL enabled.
When I build and run Example B1 to check things are working, I get a (seemingly) fully functional Qt5 window, but the OGL window within is all black.
Looking through the terminal output, I noted these Qt outputs at the very start:
$ ./exampleB1
Available UI session types: [ Qt, tcsh, csh ]
QObject::connect: No such signal QTabWidget::tabCloseRequested(G4int)
QObject::connect: No such signal QTabWidget::currentChanged(G4int)
QObject::connect: No such signal QComboBox::activated(G4int)
Geant4 version Name: geant4-11-01-patch-01 [MT] (10-February-2023)
<< in Multi-threaded mode >>
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
Is anyone able to advise if these may be causing an issue, and how I might correct them?
Thanks in advance!
