Only simulate beta, IC or Auger spectrum from a radioactive source
_Geant4 Version: 11.3.0
_Operating System: macOS
_Compiler/Version: Clang 19.1.7
_CMake Version: 3.31.6
Hi!
I want to retrieve the emitted energy from a radionuclide using Geant4 simulation. To do this, I placed my radioactive source at the center of an ‘infinite’ sphere, ensuring all emitted energy is deposited into the water medium. However, for Tb-161, I didn’t retrieve the total emitted energy: I obtained 224.08 keV in the simulation compared to 238.84 keV in the ICRP 07 data (It works for Lu-177).
Is it possible to simulate the beta, IC, Auger, X-ray or gamma spectrum individually within Geant4 directly from G4RadioactiveDecayPhysics?
In a TrackingAction’s PreUserTrackingAction you can use aTrack()->GetCreatorProcess()->GetProcessName() and check if it is radioactive decay, and then filter by particle type.
Also make sure that your PhysicsList is configured correctly, the radioactivedecay extended examples might be helpful.
Thanks for your answer!
So I set up my PreUserTrackingAction to look at Auger and IC electrons as follow:
void TrackingAction::PreUserTrackingAction(const G4Track* aTrack )
if (aTrack->GetParentID() == 2) {
FILE *myFile;
myFile = fopen (“spectrum.txt”,“a”);
fprintf (myFile, “%s %e %s \n”,
aTrack->GetDefinition()->GetParticleName().c_str(),
aTrack->GetKineticEnergy(),
aTrack->GetCreatorProcess()->GetProcessName().c_str()
fclose (myFile);
I obtain for 1 disintegration:
e- 3.403008e-03 RadioactiveDecay
gamma 4.608000e-02 RadioactiveDecay
gamma 6.481501e-03 RadioactiveDecay
e- 1.122766e-03 RadioactiveDecay
e- 3.974598e-14 RadioactiveDecay
e- 1.399626e-04 RadioactiveDecay
e- 3.676909e-05 RadioactiveDecay
Dy161[74.567] 1.164153e-08 RadioactiveDecay
I want to check yields and contributions of Auger and IC, I can filter by particle type but if I want to separate Auger and IC electrons, do I also have to filter by energy ? or maybe is possible to know from which process the particle is emitted ?
The G4RadioactiveDecay class has a SetICM(G4bool) function, so you can turn Internal Conversion off and see what sort of effect it has.
From what I understand, setICM is deprecated (or only use in PhotonEvaporation) and I have to use G4DeexPrecoParameters::SetInternalConversionFlag(G4bool) function. I’m trying to do this now.
Another question is: Do the radioactive decay process is included in the physics list (dna_opt2, std_opt4, etc…) ?
