_Geant4 Version:_10.7
_Operating System:_linux
_Compiler/Version:_c++
_CMake Version:_3.25.1
I have added mptScin->AddConstProperty(“SCINTILLATIONRISETIME”,20.7*ns); as optical properties. However, I found that the results does not change when I vary the SCINTILLATIONRISETIME.
Another problem is that , the results remain same whether I add this above line or not. Can you please tell me what is going on?
Following the macro command from OpNovice2 example, I enabled /process/optical/scintillation/setFiniteRiseTime true , However I end up in error.
------- EEEE ------- G4Exception-START -------- EEEE -------
*** G4Exception : mat202
issued by : G4MaterialPropertiesTable::GetConstProperty()
Constant Material Property Index 13 not found.
G4Track (0x55db9398cc00) - track ID = 1, parent ID = 0
Particle type : gamma - creator process : not available
Kinetic energy : 0 eV - Momentum direction : (-0.0581339,-0.484746,-0.872721)
Step length : 779.873 um - total energy deposit : 6.5133 keV
