Optical Photon detection
Geant4 Version: geant4-v11.3.0
Operating System: Windows 11 64bit
Compiler/Version: Visual Studio 2022
CMake Version: 4.0.1
Hello everyone,
I try to simulate the response of scintillation detector (EJ276) using Cs-137 as gamma source and when i run the simulation i see that few interaction of particles via Compton and photoelectric ( In PMT). I want to know the issue. Is it related to geometry or Physicslist.
This is the Geometry i have.
void DetectorConstruction::SetupGeometry() {
    // World volume - large enough to contain everything
    const G4double worldSize = 3.0 * (fScSize + fPMTLength + fLightGuideLength + 10.0 * cm);
    auto* sWorld = new G4Box("World", worldSize / 2, worldSize / 2, worldSize / 2);
    fWorldLV = new G4LogicalVolume(sWorld, fWorldMat, "WorldLV");
    fWorldLV->SetVisAttributes(fVisAttributes[0]);
    fWorldPV = new G4PVPlacement(nullptr, {}, fWorldLV, "WorldPV", nullptr, false, 0);
    // 1. Dark box (light-tight enclosure) - placed in world
    const G4double darkBoxThickness = 2.0 * mm;
    const G4double darkBoxSizeXY = fScSize + 2 * 0.5 * mm + 2 * darkBoxThickness;
    const G4double darkBoxSizeZ = fScSize + (fPMTLength + fLightGuideLength + 0.1 * mm + darkBoxThickness);
    auto* sDarkBox = new G4Box("DarkBox", darkBoxSizeXY / 2, darkBoxSizeXY / 2, darkBoxSizeZ / 2);
    G4LogicalVolume* darkBoxLV = new G4LogicalVolume(sDarkBox, fAlFoil, "DarkBoxLV");
    darkBoxLV->SetVisAttributes(G4VisAttributes(G4Colour(0.1, 0.1, 0.1)));  // Dark gray
    // Place dark box in world at origin
    G4VPhysicalVolume* darkBoxPV = new G4PVPlacement(nullptr, G4ThreeVector(0, 0, 0), darkBoxLV, "DarkBoxPV", fWorldLV, false, 0);
    // 2. Wrapping layer (0.5 mm thick) - placed in dark box
    const G4double wrapThickness = 0.5 * mm;
    // Wrap should be large enough to contain scintillator and front assembly
    const G4double wrapZ = fScSize + (fPMTLength + fLightGuideLength + 0.1 * mm);
    auto* sWrap = new G4Box("Wrap",
        fScSize / 2 + wrapThickness,
        wrapZ / 2);
    G4Material* wrapMat = fWrapType == "Teflon" ? fTeflon :
        fWrapType == "ESR" ? fESR :
        fWrapType == "AlFoil" ? fAlFoil : fTiO2Paint;
    fWrapLV = new G4LogicalVolume(sWrap, wrapMat, "WrapLV");
    fWrapLV->SetVisAttributes(fVisAttributes[2]);
    // Place wrap in dark box - offset to have scintillator at one end
    fWrapPV = new G4PVPlacement(nullptr, G4ThreeVector(0, 0, -fScSize / 2), fWrapLV, "WrapPV", darkBoxLV, false, 0);
    // 3. Scintillator - placed at one end of wrap
    auto* sScint = new G4Box("Scintillator", fScSize / 2, fScSize / 2, fScSize / 2);
    fScintillatorLV = new G4LogicalVolume(sScint, fScintMat, "ScintillatorLV");
    fScintillatorLV->SetVisAttributes(fVisAttributes[1]);
    // Place scintillator at the negative Z end of wrap (one side only)
    fScintillatorPV = new G4PVPlacement(nullptr,
        G4ThreeVector(0, 0, -wrapZ / 2 + fScSize / 2),  // At negative end of wrap
        fScintillatorLV, "ScintillatorPV", fWrapLV, false, 0);
    // 4. Grease layer (0.1 mm)
    const G4double greaseThickness = 0.1 * mm;
    auto* sGrease = new G4Tubs("GreaseDisk", 0, fPMTRadius, greaseThickness / 2, 0, twopi);
    fGreaseLV = new G4LogicalVolume(sGrease, fGrease, "GreaseLV");
    fGreaseLV->SetVisAttributes(fVisAttributes[5]);
    // 5. Light guide (if enabled)
    if (fUseLightGuide) {
        // Conical light guide to match scintillator face to PMT diameter
        const G4double r1 = fScSize / 2;  // Match scintillator face
        const G4double r2 = fPMTRadius;   // Match PMT diameter
        auto* sLightGuide = new G4Cons("LightGuide",
            0, r1, 0, r2, fLightGuideLength / 2, 0, twopi);
        fLightGuideLV = new G4LogicalVolume(sLightGuide, fPMMA, "LightGuideLV");
        fLightGuideLV->SetVisAttributes(fVisAttributes[4]);
    // 6. PMT assembly
    auto* sPMT = new G4Tubs("PMT_tube", 0, fPMTRadius, fPMTLength / 2, 0, twopi);
    fPMTLV = new G4LogicalVolume(sPMT, fPMTGlass, "PMTLV");
    fPMTLV->SetVisAttributes(fVisAttributes[3]);
    // 7. Photocathode (thin layer inside PMT)
    const G4double photoThickness = 0.05 * mm;
    const G4double photoRadius = fPMTRadius - 0.5 * mm;  // Slightly smaller than PMT
    auto* sPhoto = new G4Tubs("PhotocathodeDisk", 0, photoRadius, photoThickness / 2, 0, twopi);
    fPhotoLV = new G4LogicalVolume(sPhoto, fBialkali, "PhotocathodeLV");
    fPhotoLV->SetVisAttributes(G4VisAttributes(G4Colour(0.0, 0.0, 1.0, 0.7)));  // Blue
    // 8. PMT magnetic shield (mu-metal)
    const G4double shieldThickness = 1.0 * mm;
    auto* sShield = new G4Tubs("PMTShield",
        fPMTRadius,
        fPMTRadius + shieldThickness,
        fPMTLength / 2 + shieldThickness,
        0, twopi);
    G4LogicalVolume* shieldLV = new G4LogicalVolume(sShield, fMuMetal, "ShieldLV");
    shieldLV->SetVisAttributes(G4VisAttributes(G4Colour(0.5, 0.3, 0.1)));  // Bronze
    // Positioning INSIDE WRAP - only on positive Z side of scintillator
    // Starting from the center of the wrap volume
    G4double zPos = -wrapZ / 2 + fScSize / 2;  // Start at negative end of scintillator
    // Grease layer - placed at positive end of scintillator
    G4double zGrease = zPos + fScSize / 2 + greaseThickness / 2;
    fGreaseFrontPV = new G4PVPlacement(nullptr, G4ThreeVector(0, 0, zGrease),
        fGreaseLV, "Grease_Front", fWrapLV, false, 0);
    zPos = zGrease + greaseThickness / 2;  // Update position
    // Light guide (if used)
        G4double zLightGuide = zPos + fLightGuideLength / 2;
        new G4PVPlacement(nullptr, G4ThreeVector(0, 0, zLightGuide),
            fLightGuideLV, "LightGuide", fWrapLV, false, 0);
        zPos = zLightGuide + fLightGuideLength / 2;
    // PMT
    G4double zPMT = zPos + fPMTLength / 2;
    fPMTFrontPV = new G4PVPlacement(nullptr, G4ThreeVector(0, 0, zPMT),
        fPMTLV, "PMT", fWrapLV, false, 0);
    // Photocathode (at inner surface of PMT closest to scintillator)
    G4double zPhotoLocalFront = -fPMTLength / 2 + photoThickness / 2;
    fPhotoFrontPV = new G4PVPlacement(nullptr,
        G4ThreeVector(0, 0, zPhotoLocalFront),
        fPhotoLV,
        "Photocathode",
        fPMTLV,
        false,
        0);
    // PMT shield
    G4double zShield = zPos + (fPMTLength / 2 + shieldThickness / 2);
    new G4PVPlacement(nullptr, G4ThreeVector(0, 0, zShield),
        shieldLV, "PMTShield", fWrapLV, false, 0);
Add Properties
void DetectorConstruction::SetScintMPT(G4Material* m, const G4String& tag) {
    std::vector<G4double> E; BuildEnergyGrid(E);
    std::vector<G4double> fast(E.size()), slow(E.size()), rindex(E.size()), absl(E.size());
    G4double fastTau, slowTau, fracFast, yield, birks;
    if (tag == "EJ200") {
        // EJ-200: Fast plastic scintillator
        for (size_t i = 0; i < E.size(); ++i) {
            const G4double Ev = E[i] / eV;
            fast[i] = gaussian(Ev, 3.0, 0.3);  // Peak at 413 nm
            slow[i] = 0.1 * gaussian(Ev, 3.0, 0.4);  // Small slow component
            rindex[i] = 1.58;
            absl[i] = 250. * cm;
        fastTau = 2.1 * ns;
        slowTau = 10.0 * ns;
        fracFast = 0.95;  // Mostly fast
        yield = 10000. / MeV;
        birks = 0.126 * mm / MeV;
    else if (tag == "EJ212") {
        // EJ-212: General purpose plastic (similar to EJ-200)
            fast[i] = gaussian(Ev, 2.95, 0.32);  // Slightly different emission
            slow[i] = 0.15 * gaussian(Ev, 2.95, 0.45);
            rindex[i] = 1.58;
            absl[i] = 220. * cm;
        fastTau = 2.4 * ns;
        slowTau = 12.0 * ns;
        fracFast = 0.90;
        yield = 9500. / MeV;
        birks = 0.130 * mm / MeV;
    else if (tag == "EJ276") {
        // EJ-276: PSD plastic
            fast[i] = 0.7 * gaussian(Ev, 2.95, 0.25) + 0.3 * gaussian(Ev, 2.7, 0.2);
            slow[i] = 0.5 * gaussian(Ev, 2.85, 0.3) + 0.5 * gaussian(Ev, 2.6, 0.25);
            rindex[i] = 1.58;
            absl[i] = 200. * cm;
        fastTau = 3.0 * ns;
        slowTau = 17.0 * ns;
        fracFast = 0.30;  // Strong PSD capability
        yield = 9000. / MeV;
        birks = 0.115 * mm / MeV;
    else if (tag == "EJ309") {
        // EJ-309: Liquid scintillator
            fast[i] = gaussian(Ev, 2.95, 0.35);  // Peak at 420 nm
            slow[i] = 0.8 * gaussian(Ev, 2.95, 0.4);  // Strong slow component
            rindex[i] = 1.505;
            absl[i] = 300. * cm;  // Very clear liquid
        fastTau = 3.7 * ns;
        slowTau = 32.0 * ns;
        fracFast = 0.23;
        yield = 12000. / MeV;
        birks = 0.148 * mm / MeV;
    else {
        // Default - fallback to EJ-200 properties
            slow[i] = 0.2 * gaussian(Ev, 3.0, 0.4);
            rindex[i] = 1.58;
        fastTau = 2.0 * ns;
        fracFast = 0.8;
        yield = 8000. / MeV;
        birks = 0.1 * mm / MeV;
    auto* mpt = new G4MaterialPropertiesTable();
    mpt->AddProperty("RINDEX", E.data(), rindex.data(), (G4int)E.size(), true);
    mpt->AddProperty("ABSLENGTH", E.data(), absl.data(), (G4int)E.size(), true);
    mpt->AddProperty("FASTCOMPONENT", E.data(), fast.data(), (G4int)E.size(), true);
    mpt->AddProperty("SLOWCOMPONENT", E.data(), slow.data(), (G4int)E.size(), true);
    mpt->AddConstProperty("SCINTILLATIONYIELD", yield, true);
    mpt->AddConstProperty("RESOLUTIONSCALE", 1.0, true);
    mpt->AddConstProperty("FASTTIMECONSTANT", fastTau, true);
    mpt->AddConstProperty("SLOWTIMECONSTANT", slowTau, true);
    mpt->AddConstProperty("YIELDRATIO", fracFast, true);
    // Legacy aliases for compatibility
    mpt->AddProperty("SCINTILLATIONCOMPONENT1", E.data(), fast.data(), (G4int)E.size(), true);
    mpt->AddProperty("SCINTILLATIONCOMPONENT2", E.data(), slow.data(), (G4int)E.size(), true);
    mpt->AddConstProperty("SCINTILLATIONTIMECONSTANT1", fastTau, true);
    mpt->AddConstProperty("SCINTILLATIONTIMECONSTANT2", slowTau, true);
    mpt->AddConstProperty("SCINTILLATIONYIELD1", fracFast, true);
    mpt->AddConstProperty("SCINTILLATIONYIELD2", 1.0 - fracFast, true);
    // Realistic timing
    mpt->AddConstProperty("RISETIME1", 0.5 * ns, true);
    mpt->AddConstProperty("RISETIME2", 1.0 * ns, true);
    // Particle-dependent yields (important for PSD scintillators)
    mpt->AddConstProperty("ELECTRONSCINTILLATIONYIELD", yield, true);
    mpt->AddConstProperty("POSITRONSCINTILLATIONYIELD", yield, true);
    mpt->AddConstProperty("PROTONSCINTILLATIONYIELD", 0.65 * yield, true);
    mpt->AddConstProperty("DEUTERONSCINTILLATIONYIELD", 0.70 * yield, true);
    mpt->AddConstProperty("TRITONSCINTILLATIONYIELD", 0.72 * yield, true);
    mpt->AddConstProperty("ALPHASCINTILLATIONYIELD", 0.50 * yield, true);
    mpt->AddConstProperty("IONSCINTILLATIONYIELD", 0.60 * yield, true);
    m->SetMaterialPropertiesTable(mpt);
    m->GetIonisation()->SetBirksConstant(birks);
// --------------- construct geometry ---------------
G4VPhysicalVolume* DetectorConstruction::Construct() {
    // Clean previous geometry
    G4PhysicalVolumeStore::GetInstance()->Clean();
    G4LogicalVolumeStore::GetInstance()->Clean();
    G4SolidStore::GetInstance()->Clean();
    // Clear existing visualization attributes
    for (auto visAtt : fVisAttributes) {
        delete visAtt;
    fVisAttributes.clear();
    // Build geometry
    SetupVisAttributes();
    SetupGeometry();
    SetupOpticalSurfaces();
    // Geometry validation
    G4cout << G4endl;
    G4cout << "=== GEOMETRY VALIDATION ===" << G4endl;
    G4cout << "Checking for overlaps (tolerance: 0.1 mm)..." << G4endl;
    bool overlapCheck = fWorldPV->CheckOverlaps(1000, 0.1 * mm, false);
    if (overlapCheck) {
        G4cerr << "WARNING: Overlaps detected in geometry!" << G4endl;
    // Print geometry summary
    G4cout << "=== GEOMETRY SUMMARY ===" << G4endl;
    G4cout << "Scintillator: " << fScSize / mm << " mm cube of " << fScintMat->GetName() << G4endl;
    G4cout << "PMT Type: " << fPMTType << " (" << 2 * fPMTRadius / mm << " mm diameter)" << G4endl;
    G4cout << "Wrapping: " << fWrapType << " (" << fWrapReflectivity * 100 << "% reflectivity)" << G4endl;
    G4cout << "Light Guide: " << (fUseLightGuide ? "YES" : "NO");
    if (fUseLightGuide) G4cout << " (" << fLightGuideLength / mm << " mm length)";
    G4cout << G4endl;
    G4cout << "=========================" << G4endl;
    if (fDumpMPTAtInit) DumpAllMPTs(false);
    return fWorldPV;
Physicslist
PhysicsList::PhysicsList()
    : G4VModularPhysicsList(),
    fMessenger(nullptr),
    fEmPhysicsList(nullptr),
    fOptical(nullptr),
    fEmName("standard"),
    fScintillationEnabled(true),
    fCerenkovEnabled(false),
    fWLSEnabled(false),
    fRayleighEnabled(false),
    fAbsorptionEnabled(true),
    fBoundaryEnabled(true)
    SetVerboseLevel(1);
    fMessenger = new PhysicsListMessenger(this);
    // Default EM physics
    fEmName = "standard";
    fEmPhysicsList = new PhysListEmStandard(fEmName);
    RegisterPhysics(fEmPhysicsList);
    // Core physics
    RegisterPhysics(new G4EmExtraPhysics());
    RegisterPhysics(new G4DecayPhysics());
    RegisterPhysics(new G4RadioactiveDecayPhysics());
    RegisterPhysics(new G4HadronPhysicsQGSP_BIC_HP());
    // Optional neutron tracking cut
    auto* ncut = new G4NeutronTrackingCut();
    ncut->SetTimeLimit(NEUTRON_TIME_LIMIT);
    RegisterPhysics(ncut);
    // Optical physics
    fOptical = new G4OpticalPhysics();
    RegisterPhysics(fOptical);
    ConfigureEMParameters();
    ConfigureOpticalParameters();
PhysicsList::~PhysicsList()
    delete fMessenger;
void PhysicsList::ConstructParticle()
    G4BosonConstructor().ConstructParticle();
    G4LeptonConstructor().ConstructParticle();
    G4MesonConstructor().ConstructParticle();
    G4BaryonConstructor().ConstructParticle();
    G4IonConstructor().ConstructParticle();
    G4ShortLivedConstructor().ConstructParticle();
void PhysicsList::ConstructProcess()
    AddTransportation();
    G4VModularPhysicsList::ConstructProcess();
void PhysicsList::SetCuts()
    SetDefaultCutValue(DEFAULT_CUT_VALUE);
    G4VUserPhysicsList::SetCuts();
    G4ProductionCutsTable::GetProductionCutsTable()->SetEnergyRange(100 * eV, 1 * GeV);
    if (verboseLevel > 0) DumpCutValuesTable();
void PhysicsList::AddPhysicsList(const G4String& name)
    if (name == fEmName) return;
    G4VPhysicsConstructor* newList = nullptr;
    if (name == "standard")
        newList = new PhysListEmStandard(name);
    else if (name == "livermore")
        newList = new PhysListEmLivermore(name);
    else if (name == "penelope")
        newList = new PhysListEmPenelope(name);
    else {
        G4cout << "[PhysicsList] Unknown EM physics: " << name << G4endl;
        return;
    fEmPhysicsList = newList;
    fEmName = name;
    ReplacePhysics(fEmPhysicsList);
    G4RunManager::GetRunManager()->PhysicsHasBeenModified();
    G4cout << "[PhysicsList] Switched EM physics to: " << fEmName << G4endl;
void PhysicsList::ConfigureEMParameters()
    auto* ep = G4EmParameters::Instance();
    ep->SetDefaults();
    ep->SetVerbose(verboseLevel);
    ep->SetMinEnergy(100 * eV);
    ep->SetMaxEnergy(10 * TeV);
    ep->SetNumberOfBinsPerDecade(20);
    ep->SetMscRangeFactor(0.02);
    ep->SetFluo(true);
    ep->SetAuger(true);
    ep->SetPixe(true);
    ep->SetBuildCSDARange(true);
    ep->SetLossFluctuations(true);
    ep->SetIntegral(false);
void PhysicsList::ConfigureOpticalParameters()
    auto* op = G4OpticalParameters::Instance();
    op->SetProcessActivation("Scintillation", fScintillationEnabled);
    op->SetProcessActivation("Cerenkov", fCerenkovEnabled);
    op->SetProcessActivation("OpAbsorption", fAbsorptionEnabled);
    op->SetProcessActivation("OpBoundary", fBoundaryEnabled);
    op->SetProcessActivation("OpRayleigh", fRayleighEnabled);
    op->SetProcessActivation("WLS", fWLSEnabled);
    op->SetScintTrackSecondariesFirst(true);
    op->SetScintStackPhotons(true);
    op->SetScintByParticleType(false);
void PhysicsList::SetProcessActive(const G4String& pname, G4bool on)
    op->SetProcessActivation(pname, on);
G4bool PhysicsList::IsProcessActive(const G4String& pname) const
    if (pname == "Scintillation") return fScintillationEnabled;
    if (pname == "Cerenkov") return fCerenkovEnabled;
    if (pname == "OpAbsorption") return fAbsorptionEnabled;
    if (pname == "OpBoundary") return fBoundaryEnabled;
    if (pname == "OpRayleigh") return fRayleighEnabled;
    if (pname == "WLS") return fWLSEnabled;
    return false;
void PhysicsList::ListActiveProcesses() const
    G4cout << "=== Active Optical Processes ===" << G4endl;
    G4cout << "Scintillation: " << (fScintillationEnabled ? "ON" : "OFF") << G4endl;
    G4cout << "Cerenkov:      " << (fCerenkovEnabled ? "ON" : "OFF") << G4endl;
    G4cout << "OpAbsorption:  " << (fAbsorptionEnabled ? "ON" : "OFF") << G4endl;
    G4cout << "OpBoundary:    " << (fBoundaryEnabled ? "ON" : "OFF") << G4endl;
    G4cout << "OpRayleigh:    " << (fRayleighEnabled ? "ON" : "OFF") << G4endl;
    G4cout << "WLS:           " << (fWLSEnabled ? "ON" : "OFF") << G4endl;
    G4cout << "==============================" << G4endl;
Hi @Al_Harith
Thank you for your question.
You may start by simply scoring energy deposited in the scintillating material as a first approximation.
You can find full description of how to setup a Geant4 application from scratch in the beginners course [1] (recording available as attachment in each block of the timetable)
Best,
Alvaro
[1] First steps with Geant4 (19-23 May 2025): Timetable · Indico
Thank for your reply.
Still i get same results as before.
That is very unexpected since it should be independent of optical physics. What are the dimensions of your plastic? fScSize is mentioned in your code snippets but not its actual value. Plastics have very bad cross sections with gamma rays as a combination of both a low Z value (bad for PE) and low density (bad for both).
I set to 40 mm (Cube).
