Dear experts,
I am unable to setup my geometry (material properties and optical surfaces) to have optical photons crossing a given material. I try to explain better what I am trying to achieve in the following example.
I have multiple layers of material (aerogel) embedded in a common vessel volume (mother volume).
Both the aerogel layers and the vessel are made of materials with defined refractive index.
For the vessel case, the refractive index is set to 1 to inhibit Cherenkov radiation.
The aergel layer index is > 1, which is where I want Cherenkov photons to be generated.
In the way I have setup the geometry, I can produce Cherenkov photons in the aerogel layer.
They exit the aerogel-vessel boundary and are correctly propagated in the vessel.
The trouble is that when they encounter a following vessel-aerogel boundary they are absorbed instead of being propagated through the next aerogel layer, which is what I would like to achieve.
I believe this might have something to do with the way I defined the G4OpticalSurface and the G4LogicalBorderSurface, but I am unable to find the correct answer.
Here is a little snippet of the code
/** the vessel is a tube located in the world volume **/
auto vessel_pv = new G4PVPlacement(nullptr, G4ThreeVector(0., 0., 0), vessel_lv,
"vessel_pv",
world_lv, false, 0, false);
/** the aerogel layers are tubes as well and are created in a loop **/
for (int ilayer ...) {
/** here we create the material, solid and logical volume
the volume placement is in the vessel.
the aerogel and vessel physical volumes overlap **/
auto aerogel_pv = new G4PVPlacement(nullptr, G4ThreeVector(0., 0., 0), aerogel_lv,
std::string("aerogel_pv") + std::to_string(ilayer),
vessel_lv, false, 0, false);
/** for each aerogel volume we create an optical surface (see below this part) **/
auto aerogel_os = ConstructOpticalSurfaceAerogel(std::string("aerogel_os") + std::to_string(ilayer));
/** and for each aerogel volume we define a logical border surface between the aerogel and the vessel **/
auto aerogel_ls = new G4LogicalBorderSurface(std::string("aerogel_ls") + std::to_string(ilayer),
vessel_pv, aerogel_pv, aerogel_os);
/** optical surface is constructed such to have 100% transmittance and no reflectivity **/
G4OpticalSurface *
DetectorConstruction::ConstructOpticalSurfaceAerogel(std::string name)
G4double energy[2] = { 1.2915 * eV, 5.166 * eV };
G4double reflectivity[2] = {0., 0.};
G4double transmittance[2] = {1., 1.};
auto mpt = new G4MaterialPropertiesTable();
mpt->AddProperty("REFLECTIVITY", energy, reflectivity, 2);
mpt->AddProperty("TRANSMITTANCE", energy, reflectivity, 2);
auto os = new G4OpticalSurface(name);
os->SetType(dielectric_dielectric);
os->SetFinish(polished);
os->SetModel(glisur);
os->SetMaterialPropertiesTable(mpt);
return os;
Many thanks for any help.
Roberto
