Periodic Boundary Condition Visualisation
Geant4 Version: 11.3.2
Operating System: Ubuntu 24.04.4 LTS, run on WSL
Compiler/Version: g++ 13.3.0
CMake Version: 3.28.3
I have a Biopsy sample that I am modelling radioactive decay within, and to mimic the surrounding tissue, I have created a periodic boundary condition usng a custom PostStepDoIt to wrap interacting particles back into to the volume.
The condition is working as expected, in that the particle exits one side, reappears at the other and continues its journey with no energy lost during the jump.
However, when I visualise the particle I can see a track through the sample during the jump. Is there a way of turning off the trajectory just for this part?
Below is my PostStepDoIt section;
G4VParticleChange* PeriodicBoundaryProcess::PostStepDoIt(const G4Track& aTrack,
                                                         const G4Step& aStep)
// Safety check
    if (!fDimensionsFound) {
        FindBiopsyDimensions();
        // If still not found, can't apply PBC
        if (!fDimensionsFound) return &fParticleChange;
    fParticleChange.Initialize(aTrack);
    const G4StepPoint* postStepPoint = aStep.GetPostStepPoint();
    //Only act at geometry boundary
    if (postStepPoint->GetStepStatus() != fGeomBoundary) return &fParticleChange;
    fOldPosition = postStepPoint->GetPosition();
    G4double tol = 100.0 * G4GeometryTolerance::GetInstance()->GetSurfaceTolerance();
    bool onBoundaryX = fPeriodicX && (std::abs(std::abs(fOldPosition.x()) - fHalfLengths.x()) < tol);
    bool onBoundaryY = fPeriodicY && (std::abs(std::abs(fOldPosition.y()) - fHalfLengths.y()) < tol);
    bool onBoundaryZ = fPeriodicZ && (std::abs(std::abs(fOldPosition.z()) - fHalfLengths.z()) < tol);
    // If internal hit
    if (!onBoundaryX && !onBoundaryY && !onBoundaryZ) {
        // Silent return
    // WRAPPING LOGIC
    const G4DynamicParticle* dp = aTrack.GetDynamicParticle();
    fOldMomentum = dp->GetMomentumDirection();
    fNewPosition = fOldPosition;
    fNewMomentum = fOldMomentum;
    G4bool valid;
    G4ThreeVector normal = G4TransportationManager::GetTransportationManager()
                              ->GetNavigatorForTracking()
                              ->GetGlobalExitNormal(fNewPosition, &valid);
    if (!valid) return &fParticleChange;
//Push particle strictly inside volume
    G4double epsilon = std::max(1e-5*mm, 100.0*G4GeometryTolerance::GetInstance()->GetSurfaceTolerance());
    bool wrapped = false;
    G4String wrappedAxes = "";
    // --- X ---
    if (onBoundaryX && std::abs(normal.x()) > 0.5) {
        fNewPosition.setX(-fOldPosition.x() + (normal.x() > 0 ? +epsilon : -epsilon));
        wrapped = true;
        wrappedAxes += "X";
    // --- Y ---
    if (onBoundaryY && std::abs(normal.y()) > 0.5) {
        fNewPosition.setY(-fOldPosition.y() + (normal.y() > 0 ? +epsilon : -epsilon));
        wrapped = true;
        wrappedAxes += (wrappedAxes.empty() ? "Y" : ",Y");
    // --- Z ---
    if (onBoundaryZ && std::abs(normal.z()) > 0.5) {
        fNewPosition.setZ(-fOldPosition.z() + (normal.z() > 0 ? +epsilon : -epsilon));
        wrapped = true;
        wrappedAxes += (wrappedAxes.empty() ? "Z" : ",Z");
    if (!wrapped) {
    // Update the ParticleChange
    fParticleChange.ProposePosition(fNewPosition);
    fParticleChange.ProposeMomentumDirection(fNewMomentum);
    G4Navigator* nav = G4TransportationManager::GetTransportationManager()
                        ->GetNavigatorForTracking();
    nav->LocateGlobalPointAndSetup(fNewPosition, &fNewMomentum, false, false);
    aTrack.GetStep()->GetPostStepPoint()->SetStepStatus(fUndefined);
Hi Elizabeth
I can’t see an easy way of turning off the trajectory for the jump. The vis system is pretty dumb - it just draws the trajectory as built from the steps of the track.
What you’re doing is pretty advanced. Maybe you could make a new track after the jump? It starts to get complicated. I wouldn’t advise it.
Sorry.
