I installed Geant4 on a Server(CentOs 7 without Desktop system)
When I try to run example B1, I get the error
Reference Physics List QBBC
terminate called after throwing an instance of ‘std::logic_error’ what(): basic_string: construction from null is not valid
GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-120.el7
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /public/home/CIAENSG/geant4/install/share/Geant4/examples/basic/B1/build/exampleB1...done.
(gdb) run.mac
Starting program: /public/home/CIAENSG/geant4/install/share/Geant4/examples/basic/B1/build/exampleB1 .mac
Dwarf Error: wrong version in compilation unit header (is 5, should be 2, 3, or 4) [in module /public/apps/gcc/13.2/lib64/libstdc++.so.6]
warning: File "/public/apps/gcc/13.2/lib64/libstdc++.so.6.0.32-gdb.py" auto-loading has been declined by your `auto-load safe-path' set to "$debugdir:$datadir/auto-load:/usr/bin/mono-gdb.py".
To enable execution of this file add
add-auto-load-safe-path /public/apps/gcc/13.2/lib64/libstdc++.so.6.0.32-gdb.py
line to your configuration file "/public/home/CIAENSG/.gdbinit".
To completely disable this security protection add
set auto-load safe-path /
For more information about this security protection see the
"Auto-loading safe path" section in the GDB manual. E.g., run from the shell:
info "(gdb)Auto-loading safe path"
Dwarf Error: wrong version in compilation unit header (is 5, should be 2, 3, or 4) [in module /public/apps/gcc/13.2/lib64/libgcc_s.so.1]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Geant4 version Name: geant4-11-02-patch-01 [MT] (16-February-2024)
<< in Multi-threaded mode >>
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
terminate called after throwing an instance of 'std::logic_error'
Program received signal SIGABRT, Aborted.
0x00002aaab2e87387 in raise () from /lib64/libc.so.6
Missing separate debuginfos, use: debuginfo-install glibc-2.17-317.el7.x86_64
I think The problem mainly stems from the presence of multiple GCCs on the server.
