PhysicsList for ionizing radiation shielding
_Geant4 Version: 11.1.0
_Operating System: Windows 10
_Compiler/Version: Visual Studio 17.9
_CMake Version: 3.25.1
Hello everybody,
I am simulating the mass attenuation coefficient for different compounds using gamma radiation at various energy ranges.
Which physics lists should I use to ensure accurate results?
Thanks in advanced
To calculate mass attenuation coefficient you must calculate as a counter of the gammas with and without target.
I = no of gammas after target
I0 = no. of gammas hitting target
You can use
#include “Shielding.hh”
as it already includes “G4EmStandardPhysics_option4.hh” or else you can choose only
Source: Shielding Physics List Description
VRS
Thank you for your response.
Do you mean I need to count number of photons reach the detector with and without the target? For example if I start with 100000 primaries this will be Io and I will be the number of gamma reaches the detector. Is that correct?
Second thing, is “Shielding.hh” is enough for low gamma energy such as 0.511 MeV?
I appreciate your responses.
The most current documentation can be found here:
and in particular the Electromagnetic options are here:
Have a read and confirm they cover the energy range you are interested in.
/Pico
Thank you all.
I just want to confirm if all I need is to record the “number” of photons with and without a shielding material. Is that correct or should I record something else?
Best regards
@OdaiSuad
Yes only photons with ParentID()==1
Kill all secondaries.
VRS
Thank you. Very helpful
Hi again,
Should ParentID()==1 or 0 ? To my understanding, if ParentID()==0 then this is a primary, otherwise it is a secondary.
Am I correct?
Thank you for your response and collaboration
@OdaiSuad
Yes … parent_ID = 0 indicates a primary particle
VRS
Hi again
I shoot 1000 gamma photons with 0.511 MeV to the NaI detector. The target is to count how many photons reach the detector. Every time I get 6644577 photons reach the detector.
I am attaching some of my files:
main.cc (1.8 KB)
SteppingAction.cc (706 Bytes)
PrimaryGeneratorAction.cc (974 Bytes)
DetectorConstruction.cc (1.9 KB)
Any idea or guidance will be highly appreciated
@drvijayraj any help please?
Should I construct a sensitive detector to get an accurate number?
I also gun 1 photon and get 4 in the detector.
Thanks in advance
Dear @OdaiSuad
If you check example B1 then you can have an idea how you can have integrated counts in a scoring volume [detector/target/both].
Score at the end of event or at end of run via PostUserTrackingAction.
Since you are not doing any Physics for creating secondaries therefore you may opt em_op1.
PhysicsList = new G4EmStandardPhysics_option1();
Scoring …
EA->AddCount(1);
or
RA->AddCount(1);
In generating particles you can restrict it to 1 in PGA [better choice];
fParticleGun = new G4ParticleGun(1);
Add eventID when scoring.
Please look testem0 and em1 example for further understanding
Hi Dear @drvijayraj
I am a newcomer and would like to understand how to count the number of particles based on recorded energy deposition. Could you please explain the underlying logic? :pray:
Dear @saimegemenyucel ,
please do not hijack someone else’s thread. To get your question read by the people in the forum please create your own.
/Pico
I did not mean to hijack. I already post my own questions but still could not figure this. Since my question is related I wanted to ask also here. Maybe this can also help to question owner too I believe.
Please look example B1, testem0 and testem1. It will help you to know how to count particles.
If you check testem1 TrackingAction lines 89 to 96
  if (aTrack->GetDefinition()->GetPDGCharge() == 0.) {
    run->CountTraks0(1);
    run->CountSteps0(nbSteps);
  } else {
    run->CountTraks1(1);
    run->CountSteps1(nbSteps);
This is how you will have counts in scoring volume.
The same you can do at the end of eventaction.
Please follow examples as said.
