I have a program to model scintillation in different scintillator/PMT combinations irradiated by various particle beams. It outputs a file of the number of scintillation and PMT photons for each event and it has been working for several years. I use my own custom Physics List because I have to modify particle-specific aspects of the scintillation. It most recently worked successfully in February 2020 under Geant4 10.5.1.
I have since upgraded to Geant4 10.6.1 and the program now fails to work. It now outputs an error message:
" -------- EEEE ------- G4Exception-START -------- EEEE -------
*** G4Exception : had001
issued by : G4CrossSectionDataStore::BuildPhysicsTable
No cross section is registered for proton
-------- EEEE -------- G4Exception-END --------- EEEE -------"
and halts. If I run it under the debugger I get
"-------- EEEE ------- G4Exception-START -------- EEEE -------
Program received signal SIGABRT, Aborted.
0x00007ffff09a0a25 in raise () from /lib64/libc.so.6
Missing separate debuginfos, use: dnf debuginfo-install bzip2-libs-1.0.8-2.fc32.x86_64 expat-2.2.8-2.fc32.x86_64 freetype-2.10.1-2.fc32.x86_64 glib2-2.64.3-1.fc32.x86_64 graphite2-1.3.14-1.fc32.x86_64 harfbuzz-2.6.4-3.fc32.x86_64 libICE-1.0.10-3.fc32.x86_64 libSM-1.2.3-5.fc32.x86_64 libX11-1.6.9-3.fc32.x86_64 libXau-1.0.9-3.fc32.x86_64 libXext-1.3.4-3.fc32.x86_64 libXmu-1.1.3-3.fc32.x86_64 libXt-1.2.0-1.fc32.x86_64 libgcc-10.1.1-1.fc32.x86_64 libgcrypt-1.8.5-3.fc32.x86_64 libglvnd-1.3.1-1.fc32.x86_64 libglvnd-glx-1.3.1-1.fc32.x86_64 libgpg-error-1.36-3.fc32.x86_64 libicu-65.1-2.fc32.x86_64 libpng-1.6.37-3.fc32.x86_64 libstdc+±10.1.1-1.fc32.x86_64 libuuid-2.35.2-1.fc32.x86_64 libxcb-1.13.1-4.fc32.x86_64 lz4-libs-1.9.1-2.fc32.x86_64 mesa-libGLU-9.0.1-2.fc32.x86_64 pcre2-utf16-10.35-1.fc32.x86_64 qt5-qtbase-5.13.2-5.fc32.x86_64 qt5-qtbase-gui-5.13.2-5.fc32.x86_64 systemd-libs-245.4-1.fc32.x86_64 zlib-1.2.11-21.fc32.x86_64
(gdb) traceback
Undefined command: “traceback”. Try “help”.
(gdb) trace back
Tracepoint 1 at 0x7ffff0da3c00 (9 locations)
(gdb) where
#0 0x00007ffff09a0a25 in raise () from /lib64/libc.so.6
#1 0x00007ffff0989895 in abort () from /lib64/libc.so.6
#2 0x00007ffff0f779cd in G4Exception(char const*, char const*, G4ExceptionSeverity, char const*) ()
from /home/jmcfee/geant4/geant4.10.6.p01-install/lib64/libG4global.so
#3 0x00007ffff0f77b60 in G4Exception(char const*, char const*, G4ExceptionSeverity, std::__cxx11::basic_ostringstream<char, std::char_traits, std::allocator >&) ()
#4 0x00007ffff24b0bcc in G4CrossSectionDataStore::BuildPhysicsTable(G4ParticleDefinition const&) ()
from /home/jmcfee/geant4/geant4.10.6.p01-install/lib64/libG4processes.so
#5 0x00007ffff24f0448 in G4HadronicProcess::BuildPhysicsTable(G4ParticleDefinition const&) ()
#6 0x00007ffff6365ca7 in G4VUserPhysicsList::BuildPhysicsTable(G4ParticleDefinition*) () from /home/jmcfee/geant4/geant4.10.6.p01-install/lib64/libG4run.so
#7 0x00007ffff636670e in G4VUserPhysicsList::BuildPhysicsTable() ()
#8 0x00007ffff634f3fe in G4RunManagerKernel::BuildPhysicsTables(bool) ()
#9 0x00007ffff634f90e in G4RunManagerKernel::RunInitialization(bool) ()
–Type for more, q to quit, c to continue without paging–
#10 0x00007ffff6340b24 in G4RunManager::RunInitialization() ()
#11 0x00007ffff633bd2d in G4RunManager::BeamOn(int, char const*, int) ()
#12 0x00007ffff6346dbb in G4MTRunManager::Initialize() ()
#13 0x000000000040815a in main (argc=3, argv=0x7fffffffcad8)
at /home/jmcfee/geant4_workdir/OpLaCl3AccumulateGPS/OpNovice.cc:147
(gdb) "
I have made no changes to the code between the 10.5.1 and 10.6.1 runs except to add a line “#include “G4Types.hh”” at the beginning of main to eliminate a compile error in the kernel initialization line in main: “runManager->Initialize();”:
“In function ‘int main(int, char**)’:
/home/jmcfee/geant4_workdir/OpLaCl3AccumulateGPS/OpNovice.cc:122:3: error: ‘G4MTRunManager’ was not declared in this scope; did you mean ‘G4RunManager’?
122 | G4MTRunManager * runManager = new G4MTRunManager;”
I have attached my Physicslist. I can find no obvious problem with it.
Any help is gratefully appreciated. Thanks, John.
OpNovicePhysicsListMessenger.cc (3.9 KB)
