Positron annihilation in G4Air?
Setup: A world volume box, Na 22 source
While using G4 air, I see position annihilation happening, the emission of two 180-degree photons. I am confused about whether this is realistic or if I need to change my material definition.
While using a vacuum-like material, I am not observing the positron annihilation.
Can someone please point out any inadequacies in the material and/or physics definitions that I am missing here ?
Material: G4 Air
FindOrBuildMaterial("G4_AIR")
Material: Galalactic
G4Material("Galactic", 1., 1.01*g/mole, CLHEP::universe_mean_density, kStateGas, 2.73*kelvin, 3.e-18*pascal);
Thanks a lot!
Think about the “reality” of what you’ve set up. Na-22 decays emitting a positron, right? If that positron hits material (G4_Air) with actual atoms, it should annihilate, giving you a couple of 511 keV gammas.
Your “Galactic” or “G4_Galactic” is defined with a density of 1e-25 g/cm3, or 0.06 atoms/cm3. That’s about 16 cm between atoms. How big is your box? 1 m? Then that positron might only encounter ~6 atoms or less before it leaves the world, so positron annihilation is quite unlikely.
If you run TestEm0 with attached macro, you will see that mean free path for annihilation of positron is ~84 m in Air and ~1.6e+7 parsec in Galactic.
kitu.mac.txt (242 Bytes)
