I’m really new to data structures and such and so a little bit lost. I followed the installation guide and so far the main installation seemed to have worked. I got three directories
geant4.10.03.p03
geant4-build
geant4.10.03.p03-install
Additionally I tried the command
cmake -DGEANT_INSTALL_DATA=ON /path/to/geant4.10.03.p03-install/share/Geant4-10.3.3
and because I didn’t know which one was right I also tried:
To my understanding this should install the data files (which you can also download manually). But I am not quiete sure how to understand what is happening.
In my geant4.10.03.p03-install
directory I can’t find any directory named data
as I have seen in other examples.
When I try to setup the environment variables via
source /path/to/geant4.10.03.p03-install/bin/geant4.sh
I get a bunch of error messages looking like this:
-bash: cd: /path/to/geant4.10.03.p03-install/bin/../share/Geant4-10.3.3/data/G4NDL4.5: No such file or directory
Similiar when I try to run one of the examples (e.g. B1) I get the following error:
Available UI session types: [ GAG, tcsh, csh ]
-------- EEEE ------- G4Exception-START -------- EEEE ------- *** G4Exception : PART70001 issued by : G4NuclideTable ENSDFSTATE.dat is not found. *** Fatal Exception *** core dump *** -------- EEEE -------- G4Exception-END --------- EEEE -------
*** G4Exception: Aborting execution *** Abort trap: 6
Would appreciate some help on how to fix these problems. Thank you!
