I am using geant4.10.3p2 and EMLivermore list for the electron.
When I generated a few MeV electrons in pure water.
As a result, the amount of Cherenkov light, is not consistent with the real data.
Also, the inconsistency has energy dependence of electrons.
In my understanding, Cherenkov radiation theory is concreted, so I think the cause of this inconsistency is dE/dx or the transportation of the electron…
Under assuming the other component (geometry, detector and so on) completely reproduce real situation, what list (model) is “best” for the ~ 10 MeV energy range in Geant4.10.3?
electron dEdx is a part of practically all simulations with Geant4. If it is wrong then everything wrong in Geant4 simulation. We may discuss only % of accuracy for a particular setup.
Cerenkov is also validated (not on the same level as dEdx) but there is also signal formation - how you transform Cerenkov photons into measurement in your experimental setup?
Yes, the difference that I saw is only a few percent levels.
I checked in full-detector simulation and saw the amount of light.
I found the difference comes from the Ionization model.
What model is the best for eIonization about ~10 MeV in pure water?
(G4LivermoreIonisationModel, G4PenelopeIonisationModel, or G4MollerBhabhaModel)
@civanch
