Geant4 Version: 11.2.2
Operating System: MacOS Sonoma14.2
Compiler/Version: clang-1500.1.0.2.5
CMake Version: 3.29.5
I can run exampleB1 in terminal but cannot visualize it with a direct run of
Here is how I configure to build g4:
cmake -DCMAKE_INSTALL_PREFIX=/Users/liling/geant4/install_11.2.2 -DGEANT4_INSTALL_DATA=ON -DGEANT4_USE_OPENGL_X11=OFF -DGEANT4_USE_QT=ON -DGEANT4_USE_QT_QT6=ON -DGEANT4_USE_VTK=ON -DGEANT4_USE_SYSTEM_EXPAT=OFF ../geant4-11.2.2
and configure to build exampleB1:
cmake -DCMAKE_PREFIX_PATH=/usr/local/opt/qt@5 ..
Here is what I got after running
./exampleB1
# Visualization setting
/control/execute vis.mac
# Macro file for the visualization setting in the initialization phase
# of the B1 example when running in interactive mode
# Use these open statements to open selected visualization
# Use this open statement to create an OpenGL view:
/vis/open OGL 600x600-0+0
/vis/sceneHandler/create OGL
Candidates are: ASCIITree ATree DAWNFILE G4HepRepFile HepRepFile RayTracer VRML2FILE gMocrenFile TOOLSSG_OFFSCREEN TSG_OFFSCREEN TOOLSSG_OFFSCREEN TSG_OFFSCREEN TSG_FILE Qt3D TOOLSSG_QT_ZB TSG_QT_ZB TSGQtZB TSG VtkNative VTKN VtkOffscreen VTK_OFFSCREEN VtkQt VTKQt VTKQt Vtk VTK
sub-command "/vis/sceneHandler/create" failed.
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
Qt3D (Qt3D)
TOOLSSG_QT_ZB (TSG_QT_ZB, TSGQtZB, TSG)
VtkNative (VTKN, VTKQt_FALLBACK)
VtkOffscreen (VTK_OFFSCREEN)
VtkQt (VTKQt, VTKQt, Vtk, VTK)
Default graphics system is: Vtk (based on build flags).
Use "vis/open" without parameters to get these defaults.
*** G4Exception : UIMAN0123
Invoked command has failed - see above.
Error code : 500
***** Illegal parameter (0) </vis/open OGL 600x600-0+0> *****
Command aborted (500)
Error code : 500
***** Illegal parameter (0) </control/execute vis.mac> *****
Error code : 500
I also tried Qt3D (/vis/open Qt3D) and it just crashed and said
qt.qpa.fonts: Populating font family aliases took 423 ms. Replace uses of missing font family "Garamond" with one that exists to avoid this cost.
2025-01-12 22:55:22.284 exampleB1[69829:22699347] TSM AdjustCapsLockLEDForKeyTransitionHandling - _ISSetPhysicalKeyboardCapsLockLED Inhibit
/vis/open Qt3D
/vis/sceneHandler/create Qt3D
Qt3D.Renderer.RHI.Backend: Initializing RHI with Metal backend
/vis/viewer/refresh
[1] 69829 segmentation fault ./exampleB1
I also tried vtkqt but there was only pure black:
I want to know how I can visualize it. I used to use g4 v10 before and it worked but now I cannot build that version.
I
