Dear all ,
I’m a really beginner with ROOT and I recently started to use it.
I started to work with pyROOT, since I need to use some specific Python libraries for post processing the results in which I’m working on.
Unfortunately, I got some problems to extract the information from the root files. I would like to ask, please, some suggestions taking as the reference the .root files from the B4a example. I report the python script that I used to manage the file generated, B4.root (that I am not allowed to attach here due to its format):
from ROOT import *
fileName="./build/B4.root"
myFile = ROOT.TFile.Open(fileName, "READ")
tree=myFile.Get("B4")
leaf = tree.GetBranch("Eabs").GetLeaf("Eabs")
myFile.ls(), tree.Scan(), leaf.GetValue(), tree.Print()
In Jupyter Notebook, I get printed this information:
(20, 22.873348309946593)
TFile** B4aTestRoot/build/B4.root
TFile* std_examples/B4aTestRoot/build/B4.root
KEY: TTree B4;1 Edep and TrackL
KEY: TH1D Eabs;1 Edep in absorber
KEY: TH1D Egap;1 Edep in gap
KEY: TH1D Labs;1 trackL in absorber
KEY: TH1D Lgap;1 trackL in gap
* Row * Eabs.Eabs * Egap.Egap * Labs.Labs * Lgap.Lgap *
* 0 * 43.042040 * 0 * 29.575223 * 0 *
* 1 * 27.340958 * 0 * 19.127214 * 0 *
* 2 * 45.473479 * 0 * 30.956585 * 0 *
* 3 * 4.7084119 * 0 * 1.4942436 * 0 *
* 4 * 3.6049559 * 0 * 0.7217933 * 0 *
* 5 * 3.4328333 * 0 * 0.5616289 * 0 *
* 6 * 51.597768 * 0.2504165 * 39.337433 * 0.6461602 *
* 7 * 3.3216662 * 0 * 0.4482391 * 0 *
* 8 * 44.348139 * 1.4075870 * 33.634048 * 7.6039427 *
* 9 * 3.2214064 * 0 * 0.3639539 * 0 *
* 10 * 3.1431678 * 0 * 0.3159866 * 0 *
* 11 * 29.325894 * 0 * 20.652747 * 0 *
* 12 * 48.283826 * 0 * 36.003877 * 0 *
* 13 * 31.511904 * 1.4158138 * 23.978050 * 8.1664451 *
* 14 * 32.828006 * 0 * 23.612736 * 0 *
* 15 * 10.381831 * 0 * 6.1633032 * 0 *
* 16 * 3.2690086 * 0 * 0.3967726 * 0 *
* 17 * 3.1745242 * 0 * 0.3311820 * 0 *
* 18 * 47.452206 * 7.2540443 * 33.439702 * 39.732736 *
* 19 * 22.873348 * 0 * 15.977893 * 0 *
*Tree :B4 : Edep and TrackL *
*Entries : 20 : Total = 4621 bytes File Size = 2805 *
* : : Tree compression factor = 1.00 *
*Br 0 :Eabs : Double_t B4 *
*Entries : 20 : Total Size= 1053 bytes File Size = 548 *
*Baskets : 4 : Basket Size= 32000 bytes Compression= 1.00 *
*Br 1 :Egap : Double_t B4 *
*Br 2 :Labs : Double_t B4 *
*Br 3 :Lgap : Double_t B4 *
where I am not able to extract the values of each column but only the one at the last row (22.873348309946593).
I tried to get the single values in the following way:
leaf.GetValue(1), leaf.GetValue(2), leaf.GetValue(3), leaf.GetValue(20)
by obtaining:
(0.0, 5.73e-322, 2.4e-322, 5.667e-321)
I installed the last version of ROOT and I updated jupyter and Python in the Anaconda environment, even though I don’t exclude errors due to bugs.
Do you have any suggestion, please?
Thank you very much for your time.
Christian
