Problem with definition of ion source
Geant4 Version: 10.2
Operating System: linux
Hi experts,
I encountered particle source definition issue.here is my code.
G4int Z = 92, A = 238;
G4IonTable* ionTable = G4IonTable::GetIonTable();
ionTable->CreateAllIon();
G4ParticleDefinition* particle_here = ionTable->GetIon(Z, A, 0.0);
gps_->SetParticleDefinition(particle_here);
gps_->SetParticleCharge(0.0);
And then this happened:
*** G4Exception : PART105
      issued by : G4IonTable::CreateIon()
Can not create ions because GenericIon is not ready
and then the program crashed. Should I Initialize some things before there?
Thanks for any help!!
IonTable cannot be invoked from the constructor of PrimaryGeneratorAction : too early …
It can be called in PrimaryGeneratorAction::GeneratePrimaries().
See example rdecay01 to see the ‘trick’ used.
Thank you so much for your advice!
I put the code later and the problem is solved!
thank again,that’s really helpful! :grinning:
