Hi everyone.
I’m running the same code since 5 years concerning optical simulations with the creation of scintillation and cerenkov in some materials with the tracking and all is fine.
And then, I would like to test something with a direct opticalphoton creation with gps and I obtain a segmentation fault. I dont understand why it doesnt work with optical photon generation but all is ok when optical photons are created by scintillation and/or Cerekon effect.
If you have some ideas, it will be a pleasure :).
Here the backtrace :
- G4Track Information: Particle = opticalphoton, Track ID = 1, Parent ID = 0
Step# X(mm) Y(mm) Z(mm) KinE(MeV) dE(MeV) StepLeng TrackLeng NextVolume ProcName
0 0 0 229 2.5e-06 0 0 0 Scintillator initStep
CAUGHT SIGNAL: 11 ### address: 0x130, signal = SIGSEGV, value = 11, description = segmentation violation. Address not mapped to object.
Backtrace:
[PID=733767, TID=-1][ 0/18]> ./TPSim(_ZNKSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE7compareEPKc+0x10) [0x413a00]
[PID=733767, TID=-1][ 1/18]> ./TPSim() [0x41a1ed]
[PID=733767, TID=-1][ 2/18]> /usr/local/geant4.11.0.1/lib64/libG4tracking.so(_ZN17G4TrackingManager15ProcessOneTrackEP7G4Track+0x220) [0x7fea037b2550]
[PID=733767, TID=-1][ 3/18]> /usr/local/geant4.11.0.1/lib64/libG4event.so(_ZN14G4EventManager12DoProcessingEP7G4Event+0x7cc) [0x7fea039ed16c]
[PID=733767, TID=-1][ 4/18]> /usr/local/geant4.11.0.1/lib64/libG4run.so(_ZN12G4RunManager11DoEventLoopEiPKci+0xaf) [0x7fea03c9859f]
[PID=733767, TID=-1][ 5/18]> /usr/local/geant4.11.0.1/lib64/libG4run.so(_ZN12G4RunManager6BeamOnEiPKci+0x5e) [0x7fea03c967de]
[PID=733767, TID=-1][ 6/18]> /usr/local/geant4.11.0.1/lib64/libG4run.so(_ZN14G4RunMessenger11SetNewValueEP11G4UIcommand8G4String+0x509) [0x7fea03cc9829]
[PID=733767, TID=-1][ 7/18]> /usr/local/geant4.11.0.1/lib64/libG4intercoms.so(_ZN11G4UIcommand4DoItE8G4String+0x347) [0x7fe9ff90e347]
[PID=733767, TID=-1][ 8/18]> /usr/local/geant4.11.0.1/lib64/libG4intercoms.so(_ZN11G4UImanager12ApplyCommandEPKc+0x682) [0x7fe9ff925e32]
[PID=733767, TID=-1][ 9/18]> /usr/local/geant4.11.0.1/lib64/libG4intercoms.so(_ZN9G4UIbatch11ExecCommandERK8G4String+0x17) [0x7fe9ff8fe0d7]
[PID=733767, TID=-1][10/18]> /usr/local/geant4.11.0.1/lib64/libG4intercoms.so(_ZN9G4UIbatch12SessionStartEv+0x75) [0x7fe9ff8ff115]
[PID=733767, TID=-1][11/18]> /usr/local/geant4.11.0.1/lib64/libG4intercoms.so(_ZN11G4UImanager16ExecuteMacroFileEPKc+0x3c) [0x7fe9ff92757c]
[PID=733767, TID=-1][12/18]> /usr/local/geant4.11.0.1/lib64/libG4intercoms.so(_ZN20G4UIcontrolMessenger11SetNewValueEP11G4UIcommand8G4String+0x23b) [0x7fe9ff91b23b]
[PID=733767, TID=-1][13/18]> /usr/local/geant4.11.0.1/lib64/libG4intercoms.so(_ZN11G4UIcommand4DoItE8G4String+0x347) [0x7fe9ff90e347]
[PID=733767, TID=-1][14/18]> /usr/local/geant4.11.0.1/lib64/libG4intercoms.so(_ZN11G4UImanager12ApplyCommandEPKc+0x682) [0x7fe9ff925e32]
[PID=733767, TID=-1][15/18]> ./TPSim() [0x40ff20]
[PID=733767, TID=-1][16/18]> /usr/lib64/libc.so.6(__libc_start_main+0xf3) [0x7fe9fe1f8ca3]
[PID=733767, TID=-1][17/18]> ./TPSim() [0x4114ce]
: Segmentation fault (Address not mapped to object [0x130])
Abandon (core dumped)
