Hello Geant4 experts,
I am a Geant4 beginner, and I run simulations with some _HP or _AllHP models of Reference Physics Lists now.
I have a question about the UI command: /process/had in the multi-threading (MT) case.
I found that the commands, such as process/had/rdm/thresholdForVeryLongDecayTime 1.0e+60 year, /process/had/particle_hp/skip_missing_isotopes true, /process/had/particle_hp/do_not_adjust_final_state true
are conducted in the serial mode, but NOT applied in the MT mode.
In the MT case, these are always set to the default ones, i.e. threshold time=1 yr, skip missing isotope false, don’t adjust final state false, respectively.
How can I set these parameters as I want in MT case? The following information is about the version I am using now.
If you need additional information to answer my question, please tell me. Thank you.
_Geant4 Version:_11.2.0
_Operating System:_MacOS Ventura 13.6.4
_Compiler/Version:_Apple clang version 14.0.3
_CMake Version:_3.28.1
