Processing opticalphoton event info into ROOT file via multithreading mode
Dear Geant4 Experts
I am facing problem while processing the opticalphoton info into a ROOT file when I am processing the events in multi thread mode. Here is a situation: I am shooting gamma rays over a scintillator bar, and the resulting optical photons attributes I am storing into a ROOT file. The situation is fine with a single thread, but when I am running in multi-thread, then, the output file is not reproduced as that of a single thread case for the same no. of gamma-ray shoots. I have the feeling that in multi-thread mode, the gamma-ray energy deposition is catered by one thread while the optical photon processing is done by another thread, so when I am creating the ROOT file, it leaves the useful events. I don’t know how to tackle this situation. I came to know the example OpNovice but I don’t exactly got the concept of G4Run::Merge(run).
I also notices that no. of event starts and stop print outputs are not equal in single and multi thread?
I am attaching the output files (for 190 gamma-ray shoots) of my terminal in case of single and two thread runs files for closer inspection to the experts.
Please tell me the relevant files of my geant4 code I will upload that.
output_singleThread.txt (40.0 KB)
output_TwoThreads.txt (41.7 KB)
Are you doing all of the ROOT I/O stuff yourself? TFile, TTree, AddBranch, blah blah blah? Or are you using G4AnalysisManager to produce a ROOT-format output file? ROOT is quite thread-unsafe when used by non-ROOT applications; for CDMS, we had to make our ROOT output manager a singleton, and wrap all of the ROOT calls in mutexes (G4AutoLock).
G4AnalysisManager handles everything in a natively Geant4 way, and produces an output file that ROOT can read, without using any ROOT libraries. It may be a better option for you.
You asked,
Nope! Each whole event is handled by a single thread. You are most likely seeing the cross-thread collisions that we saw, and which required mutexing to avoid.
Thank you for the response
Yes all the ROOT I/O I am doing by myself and not using the G4AnalysisManager, can you please help me how to wrap all the ROOT calls in mutex (G4AutoLock)? and how do I avoid the cross-thread collisions. I am attaching my EventAction and RunAction files. Please help me out.
This is a old piece of code which I edited for another detector configuration, initially I was not using multi-thread, but now I seriously required.
Also provide the Geant4 directory example to understand G4AnalysisManager further.
Thanks !
SinglePlasticEventAction.cc (13.1 KB)
SinglePlasticRunAction.cc (5.8 KB)
Please, take a look at the basic example B4/B4a and also the Analysis section in the Geant4 Guide For Application Developers.
Thanks for the suggestions, Can you please tell how to implement G4Autolock in my eventaction code?
The overall documentation for multithreading, including discussions of shared vs. local memory, singletons, etc., is in the Toolkit Guide (which is aimed at the G4 developers, not end users): Parallelism in Geant4: multi-threading capabilities — Geant4 Documentation 11.3 documentation. The discussion of mutexes is towards the end, Parallelism in Geant4: multi-threading capabilities — Geant4 Documentation 11.3 documentation. In the Application Developers’ Guide, there’s a discussion of G4AutoLock in the Analysis section cited above, Analysis Manager Classes — Book For Application Developers 11.3 documentation
Thank You for the response.
So now I have to removed the custom ROOT I/O readout and used the Geant4 custom n-tuple option to fill my events in multithreading. When I am running single thread it gives the expected scintillation light spectrum but when I uses two threads then it provides completely wrong spectrum. I have implemented the code snippet given in example B4a, what could be potentially wrong here. In the end of event action I am doing something like.
	     analysisManager->FillNtupleDColumn(0,SumEn1);
	     analysisManager->FillNtupleDColumn(1,gammatime1 / nofhits1);
	     analysisManager->FillNtupleDColumn(2, fStepping->n_scint1);
	     analysisManager->FillNtupleDColumn(3, fStepping->n_opabs1);
	     analysisManager->FillNtupleDColumn(4, fStepping->GetAverageTime(0));
	     analysisManager->AddNtupleRow();
Kindly suggest to resolve the issue.
I just checked the correlation between threadID for gamma/e- and the optical photons. It clearly shows that the optical photons are being handled by another thread.I am stuck at this stage. Kindly help me out.
void SinglePlasticSteppingAction::UserSteppingAction(const G4Step* step)
  auto threadId = std::this_thread::get_id();
    G4cout << "Thread ID: " << threadId << " Step: "
           << step->GetTrack()->GetTrackID()
           << " Particle: " << step->GetTrack()->GetDefinition()->GetParticleName()
           << G4endl;
Here is the output :
G4WT0 > Thread ID: 140526615525056 Step: 2 Particle: gamma
G4WT1 > Thread ID: 140526607132352 Step: 2 Particle: gamma
G4WT1 > Thread ID: 140526607132352 Step: 1 Particle: gamma
G4WT0 > Thread ID: 140526615525056 Step: 22 Particle: opticalphoton
G4WT0 > Thread ID: 140526615525056 Step: 21 Particle: opticalphoton
