Hi everyone,
Setup
- GATE 9.2 (built against Geant4 11.0.0)
- 180 MeV proton pencil beam along +Z
- Water phantom: 8 × 8 × 40 cm³, centred at Z = 0 cm
- Cherenkov detector (PbF₂ crystal + grease + SiPM) 10 cm downstream of the phantom
→ goal: Study prompt-γ that leave the water and enter the crystal
Physics macro (simplified)
# --- hadron + EMY list --------------------------------------------------------
/gate/physics/addPhysicsList QGSP_BERT_HP_EMY # works: I see prompt gamma
# --- add optical + Cherenkov ------------------------------------------
/gate/physics/addPhysicsList optical # after this = 0 prompt γ
/gate/physics/addPhysicsList scintillation
/gate/physics/addPhysicsList cerenkov
With only the first line I get ≈ 5 × 10⁵ prompt gammas exiting the phantom
(as expected).
As soon as I add the three optical/scintillation/Cherenkov lines, the γ count
inside the phantom drops to zero.I tryied to write a macro and put everything in one macro but it was not helpful
Question
I suspect that calling /gate/physics/addPhysicsList optical replaces
the earlier QGSP_BERT_HP_EMY list instead of adding to it, so all hadronic
interactions (and therefore prompt γ production) are turned off.
What is the correct way in GATE 9.2 to keep QGSP_BERT_HP_EMY but add
optical, scintillation and Cherenkov processes?
If a single combined physics list exists, which one do you recommend for
180 MeV proton prompt‑γ + optical transport?
Any pointer to an example macro or doc page would be greatly appreciated.
Thank you very much!
Did you check the GATE documentation? It doesn’t look obvious to me, but my guess is that you should be using the addProcess command, though I don’t know if that works with a physics builder like “optical.”
You may need to contact the GATE community for more help.
yes , I checked it and it is /gate/physics/addPhysicsList optical
This, at first pass, seems to be a gate issue. Mostly because of how strange this issue is:
It has been shown in recent Gate releases that activating the Cherenkov using in the physics list /gate/physics/addPhysicsList empenelope (or others) /gate/physics/addProcess Cerenkov is not enough to add the Cerenkov process in a Volume one needs to define an appropriate physics cut in the volume of interest, for the particule type of interest /gate/physics/Electron/SetCutInRegion Volume 0.1 mm in order to generate Cherenkov photon. The reason of the feature is still unclear.
From the bottom of the page @mkelsey linked. That seems suspicious. Does that issue persist if you activate just the optical and scintillation?
with this condition I do not have any optical photon or cherenkov in my simulation only prompt gamma
#/gate/physics/addPhysicsList optical
/gate/physics/addProcess optical
/gate/physics/addProcess Scintillation
#/gate/physics/addProcess Cerenkov e-
#/gate/physics/addProcess Cerenkov e+
I can not find any solution for this problem, neither when I activate this line #/gate/physics/addPhysicsList optical
Try updating to the latest version or at least 11.3.2.
This might be related and it was fixed in that version.
but I think the problem is not missing optical package, when I change the source from proton to gamma and directly shoot to crystal I have cherenkov and optical process
