Thanks, I shall check that.
Just on the same topic, also if I try to run this project now, on my MacBook (Mojave 10.14),
which has Geant4.10.04 version installed.
This is error I get, when I try to execute it.
/Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5
@@@ G4ParticleHPInelastic instantiated for particle neutron data directory variable is G4NEUTRONHPDATA pointing to /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5/Inelastic
@@@ G4ParticleHPInelasticData instantiated for particle neutron data directory variable is G4NEUTRONHPDATA pointing to /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5
NeutronHP: /Capture file for Z = 8, A = 18 is not found and NeutronHP will use /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5/Capture/CrossSection/8_17_Oxygen
NeutronHP: /Elastic file for Z = 8, A = 18 is not found and NeutronHP will use /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5/Elastic/CrossSection/8_17_Oxygen
NeutronHP: /Inelastic file for Z = 8, A = 18 is not found and NeutronHP will use /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5/Inelastic/CrossSection/8_17_Oxygen
NeutronHP: /Capture file for Z = 6, A = 12 is not found and NeutronHP will use /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5/Capture/CrossSection/6_nat_Carbon
NeutronHP: /Elastic file for Z = 6, A = 12 is not found and NeutronHP will use /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5/Elastic/CrossSection/6_nat_Carbon
NeutronHP: /Inelastic file for Z = 6, A = 12 is not found and NeutronHP will use /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5/Inelastic/CrossSection/6_nat_Carbon
NeutronHP: /Capture file for Z = 6, A = 13 is not found and NeutronHP will use /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5/Capture/CrossSection/6_nat_Carbon
NeutronHP: /Elastic file for Z = 6, A = 13 is not found and NeutronHP will use /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5/Elastic/CrossSection/6_nat_Carbon
NeutronHP: /Inelastic file for Z = 6, A = 13 is not found and NeutronHP will use /Users/mansisaxena/geant4_10.04/geant4.10.04-install/share/Geant4-10.4.3/data/G4NDL4.5/Inelastic/CrossSection/6_nat_Carbon
G4OpenGLXViewer::G4OpenGLXViewer failed to allocate a standard colormap.
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 1 (X_CreateWindow)
Serial number of failed request: 26
Current serial number in output stream: 33
Also, when I do “make”, there were a lot of warnings earlier on (some below), but it creates a executable at the end.
Mansis-MacBook-Air:geant4_SuN_bDecay mansisaxena$ make
Making dependency for file sunShare_co69_to_ni69.cc …
g++.exec: error: unrecognized command line option ‘-stdlib=libc++’
Making dependency for file src/SuNBetaDecay.cc …
Making dependency for file src/SteppingAction.cc …
Making dependency for file src/RunAction.cc …
Making dependency for file src/PrimaryGeneratorAction.cc …
Making dependency for file src/EventAction.cc …
Making dependency for file src/DetectorConstruction.cc …
Compiling DetectorConstruction.cc …
clang: warning: -lCore: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lImt: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lRIO: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lNet: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lHist: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lGraf: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lGraf3d: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lGpad: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lROOTVecOps: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lTree: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lTreePlayer: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lRint: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lPostscript: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lMatrix: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lPhysics: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lMathCore: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lThread: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lMultiProc: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lROOTDataFrame: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lpthread: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -lm: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: -ldl: ‘linker’ input unused [-Wunused-command-line-argument]
clang: warning: argument unused during compilation: ‘-L/Users/mansisaxena/build_6.18/lib’ [-Wunused-command-line-argument]
Thanks. Really appreciate the help. I would like to get it up and running in my MacBook laptop too.
Wishes
M
