when i upgrade ubuntu to 20.04 and geant4 to geant4 10.6 (delete and install new version of both) i encounter with following problem.
if i run exampleB1 with this command :
./exampleB1 run1.mac
the simulation will successfully be done.
if i use openGL interface(just run ./exampleB1) and then close the opengl window (or /run/beamOn n) the result will be :
Available UI session types: [ Qt, Xm, GAG, tcsh, csh ]
G4WT1 > /control/saveHistory
G4WT0 > /control/saveHistory
G4WT0 > /run/verbose 2
G4WT1 > /run/verbose 2
G4WT0 > /run/initialize
G4WT1 > /run/initialize
G4WT0 > /run/physicsModified
G4WT1 > /run/physicsModified
or if i run AnaEx02 with this command :
./AnaEx02 run.mac
if i use openGL interface (just run ./exampleB1) and then close the opengl window (or /run/beamOn n) the result will be :
*** Break *** segmentation violation
There was a crash.
This is the entire stack trace of all threads:
Thread 9 (Thread 0x7fb8e6ffd700 (LWP 13939)):
#0 futex_wait_cancelable (private=<optimized out>, expected=0, futex_word=0x556a5ed42378) at ../sysdeps/nptl/futex-internal.h:183
#1 __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x556a5ed42328, cond=0x556a5ed42350) at pthread_cond_wait.c:508
#2 __pthread_cond_wait (cond=0x556a5ed42350, mutex=0x556a5ed42328) at pthread_cond_wait.c:638
#3 0x00007fb8f523797b in () at /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
#4 0x00007fb8f523758b in () at /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
#5 0x00007fb902583609 in start_thread (arg=<optimized out>) at pthread_create.c:477
#6 0x00007fb908abd103 in clone () at /usr/lib/x86_64-linux-gnu/libc.so.6
Thread 8 (Thread 0x7fb8e77fe700 (LWP 13938)):
Thread 7 (Thread 0x7fb8e7fff700 (LWP 13937)):
Thread 6 (Thread 0x7fb8f4ae6700 (LWP 13936)):
Thread 5 (Thread 0x7fb8f6758700 (LWP 13935)):
#0 0x00007fb908ab096f in poll () at /usr/lib/x86_64-linux-gnu/libc.so.6
#1 0x00007fb9010b21ae in () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x00007fb9010b22e3 in g_main_context_iteration () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007fb90287b565 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#4 0x00007fb9028224db in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#5 0x00007fb90265a785 in QThread::exec() () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#6 0x00007fb8fdce9efa in () at /usr/lib/x86_64-linux-gnu/libQt5DBus.so.5
#7 0x00007fb90265b9d2 in () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#8 0x00007fb902583609 in start_thread (arg=<optimized out>) at pthread_create.c:477
#9 0x00007fb908abd103 in clone () at /usr/lib/x86_64-linux-gnu/libc.so.6
Thread 4 (Thread 0x7fb8f71be700 (LWP 13934)):
#2 0x00007fb9010b2533 in g_main_loop_run () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007fb8f7f3deda in () at /usr/lib/x86_64-linux-gnu/libgio-2.0.so.0
#4 0x00007fb9010db931 in () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
Thread 3 (Thread 0x7fb8f79bf700 (LWP 13933)):
#3 0x00007fb9010b2331 in () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
Thread 2 (Thread 0x7fb8fd546700 (LWP 13932)):
#1 0x00007fb901fa6c1a in () at /usr/lib/x86_64-linux-gnu/libxcb.so.1
#2 0x00007fb901fa890a in xcb_wait_for_event () at /usr/lib/x86_64-linux-gnu/libxcb.so.1
#3 0x00007fb8fdde6298 in () at /usr/lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#4 0x00007fb90265b9d2 in () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
Thread 1 (Thread 0x7fb8feebbc40 (LWP 13931)):
#0 0x00007fb908a80c6f in wait4 () at /usr/lib/x86_64-linux-gnu/libc.so.6
#1 0x00007fb9089f00e7 in () at /usr/lib/x86_64-linux-gnu/libc.so.6
#2 0x00007fb90a493d8e in TUnixSystem::StackTrace() () at /home/k1/k1-Files/Apps/ROOT/install/lib/libCore.so
#3 0x00007fb90a490c15 in TUnixSystem::DispatchSignals(ESignals) () at /home/k1/k1-Files/Apps/ROOT/install/lib/libCore.so
#4 0x00007fb9089e1210 in <signal handler called> () at /usr/lib/x86_64-linux-gnu/libc.so.6
#5 0x00007fb902c4ad88 in QOpenGLContext::makeCurrent(QSurface*) () at /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5
#6 0x00007fb9039f764d in QGLContext::makeCurrent() () at /usr/lib/x86_64-linux-gnu/libQt5OpenGL.so.5
#7 0x00007fb9039fd685 in QGLWidgetPrivate::makeCurrent() () at /usr/lib/x86_64-linux-gnu/libQt5OpenGL.so.5
#8 0x00007fb90a9eb06f in G4OpenGLStoredQtViewer::~G4OpenGLStoredQtViewer() () at /home/k1/k1-Files/Apps/GEANT4/install/lib/libG4OpenGL.so
#9 0x00007fb90a9eb9b4 in non-virtual thunk to G4OpenGLStoredQtViewer::~G4OpenGLStoredQtViewer() () at /home/k1/k1-Files/Apps/GEANT4/install/lib/libG4OpenGL.so
#10 0x00007fb90284d01e in QObjectPrivate::deleteChildren() () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#11 0x00007fb9034e4c29 in QWidget::~QWidget() () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#12 0x00007fb90365b05d in QStackedWidget::~QStackedWidget() () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#13 0x00007fb90284d01e in QObjectPrivate::deleteChildren() () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#14 0x00007fb9034e4c29 in QWidget::~QWidget() () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#15 0x00007fb90a92ad15 in G4QTabWidget::~G4QTabWidget() () at /home/k1/k1-Files/Apps/GEANT4/install/lib/libG4interfaces.so
#16 0x00007fb90284d01e in QObjectPrivate::deleteChildren() () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#17 0x00007fb9034e4c29 in QWidget::~QWidget() () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#18 0x00007fb9035fc4bd in QMainWindow::~QMainWindow() () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#19 0x00007fb90284fb74 in QObject::event(QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#20 0x00007fb9034e925d in QWidget::event(QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#21 0x00007fb9035fe148 in QMainWindow::event(QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#22 0x00007fb9034a6a66 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#23 0x00007fb9034b00f0 in QApplication::notify(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5
#24 0x00007fb90282393a in QCoreApplication::notifyInternal2(QObject*, QEvent*) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#25 0x00007fb9028265b8 in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#26 0x00007fb90287bf67 in () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#27 0x00007fb9010b1fbd in g_main_context_dispatch () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#28 0x00007fb9010b2240 in () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#29 0x00007fb9010b22e3 in g_main_context_iteration () at /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0
#30 0x00007fb90287b565 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#31 0x00007fb9028224db in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#32 0x00007fb90282a246 in QCoreApplication::exec() () at /usr/lib/x86_64-linux-gnu/libQt5Core.so.5
#33 0x00007fb90a923b5d in G4UIQt::SessionStart() () at /home/k1/k1-Files/Apps/GEANT4/install/lib/libG4interfaces.so
#34 0x0000556a5b9b59f6 in main ()
The lines below might hint at the cause of the crash.
You may get help by asking at the ROOT forum http://root.cern.ch/forum
Only if you are really convinced it is a bug in ROOT then please submit a
report at http://root.cern.ch/bugs Please post the ENTIRE stack trace
from above as an attachment in addition to anything else
that might help us fixing this issue.
i built Geant4 with these options :
cmake -DCMAKE_INSTALL_PREFIX=/home/k1/k1-Files/Apps/GEANT4/install -DGEANT4_USE_GDML=ON -DCMAKE_BUILD_TYPE=Release -DGEANT4_INSTALL_DATA=ON -DGEANT4_USE_OPENGL_X11=ON -DGEANT4_USE_XM=ON -DGEANT4_USE_QT=ON -DGEANT4_BUILD_MULTITHREADED=ON /home/k1/k1-Files/Apps/GEANT4/geant4.10.06.p02
and this is exampleB1βs build output:
β The C compiler identification is GNU 9.3.0
β The CXX compiler identification is GNU 9.3.0
β Check for working C compiler: /usr/bin/cc
β Check for working C compiler: /usr/bin/cc β works
β Detecting C compiler ABI info
β Detecting C compiler ABI info - done
β Detecting C compile features
β Detecting C compile features - done
β Check for working CXX compiler: /usr/bin/c++
β Check for working CXX compiler: /usr/bin/c++ β works
β Detecting CXX compiler ABI info
β Detecting CXX compiler ABI info - done
β Detecting CXX compile features
β Detecting CXX compile features - done
β Found EXPAT: /usr/lib/x86_64-linux-gnu/libexpat.so (found suitable version β2.2.9β, minimum required is β2.2.9β)
β Found XercesC: /usr/lib/x86_64-linux-gnu/libxerces-c.so (found suitable version β3.2.2β, minimum required is β3.2.2β)
β Found X11: /usr/include
β Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so
β Looking for XOpenDisplay in /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so - found
β Looking for gethostbyname
β Looking for gethostbyname - found
β Looking for connect
β Looking for connect - found
β Looking for remove
β Looking for remove - found
β Looking for shmat
β Looking for shmat - found
β Looking for IceConnectionNumber in ICE
β Looking for IceConnectionNumber in ICE - found
β Found OpenGL: /usr/lib/x86_64-linux-gnu/libOpenGL.so
β Found Motif: /usr/lib/x86_64-linux-gnu/libXm.so
β Configuring done
β Generating done
β Build files have been written to: /home/k1/k1-Files/Apps/GEANT4/geant4.10.06.p02/examples/basic/B1/build
Thanks you,
Keyvan Tabaei
linux platform: ubuntu 20.04
geant4 version : 10.6
ROOT version : 6.22.02
