I was wondering if it was possible to access the information inside the folders “PhotonEvaporationX.X” and “RadioactiveDecayX.X” with some GEANT4 functions like DumpTable() or GetIonLifeTime(), etc.
Let me explain in more detail.
For particles you can get it is properties and decay modes, for example, following the code at Example showing how to retrieve particle properties
It is possible for light ions too. But basically, it is not possible for any one consider as GenericIon, from one of Vladimir Ivantchenko presentations:
“- Light ions: d, t, 3He, 4He”
“- G4GenericIon is used to define physics for all other ions”
After declaring the needed PhysicsLists, you can follow the next piece of code:
G4int ionA = 137;
G4int ionZ = 55;
G4ParticleDefinition* projectileNucleus = nullptr;
G4GenericIon* gion = G4GenericIon::GenericIon();
gion->SetProcessManager(new G4ProcessManager(gion));
G4ParticleTable* partTable = G4ParticleTable::GetParticleTable();
G4IonTable* ions = partTable->GetIonTable();
partTable->SetReadiness();
ions->CreateAllIon();
ions->CreateAllIsomer();
projectileNucleus = partTable->GetIonTable()->GetIon(ionZ, ionA, 0.0);
projectileNucleus->DumpTable();
And you are going to get the next:
--- G4ParticleDefinition ---
Particle Name : Cs137
PDG particle code : 1000551370 [PDG anti-particle code: 0]
Mass [GeV/c2] : 127.5 Width : 0
Lifetime [nsec] : 1.36948e+18
Charge [e]: 55
Spin : 7/2
Parity : 1
Charge conjugation : 0
Isospin : (I,Iz): (0/2 , 0/2 )
GParity : 0
MagneticMoment [MeV/T] : 8.95706e-14
Quark contents (d,u,s,c,b,t) : 192, 219, 0, 0, 0, 0
AntiQuark contents : 0, 0, 0, 0, 0, 0
Lepton number : 0 Baryon number : 137
Particle type : nucleus [generic]
Atomic Number : 55 Atomic Mass : 137
Stable : unstable -- lifetime = 43.426 y
Decay table should be consulted to G4RadioactiveDecayProcess.
The last sentence is coming from G4ParticleDefinition.cc, could be check here:
if (IsGeneralIon()) {
G4double lftm = GetIonLifeTime();
if (lftm < -1000.) {
G4cout << " Stable : No data found -- unknown" << G4endl;
else if (lftm < 0.) {
G4cout << " Stable : stable" << G4endl;
else {
G4cout << " Stable : unstable -- lifetime = " << G4BestUnit(lftm, "Time")
<< "\n Decay table should be consulted to G4RadioactiveDecayProcess." << G4endl;
Since, as I said before, it is a generic Ion.
Clearly, when you simulate a RadioactiveDecay, the info inside these files, “PhotonEvaporationX.X” and “RadioactiveDecayX.X”, is accessed.
So, to be more precise, is there a way that the user could access directly this information?
Thank you for your time.
Geant4 Version: v11.3.0 (tried too with v10.3.0, I think it does not matter)
Operating System: Sequoia 15.1
Compiler/Version: Apple clang version 15.0.0 (clang-1500.3.9.4)
CMake Version: 3.30.4
