Hello!
I am curious why I am having a very unrealistic gap in the efficiency of deposited energy on my detector for very little change in the photon origin. The detector size is 50mmx50mmx50mm (i.e. each side has have a dimension: -25mm < x < 25mm
The origin of the incoming photons of x0
and y0
was set randomly but between -25mm < x < 25mm
, while z0
was fixed at -12.5mm, -25mm, 27.5mm, and -50mm for four different simulations. The deposited energy away from the surface is much smaller than that on the surface for very little change of 25mm (70%) to 27.5mm (30%) even though there is nothing (vacuum) obstructing the incoming photons. However, the efficiency for 27.5mm and 50mm appear to be similar.
What could be the cause of this efficiency gap, could it be that something is wrong with my simulation.
